![]() | Home > Maintenance & Mods (L322) > Gearbox flush - Apologies |
as the gearbox's are supposed to be 'sealed for life' , any oil change with new filter can only help in preventative maintenance...
J90 Member Since: 02 Jul 2013 Location: Somewhere south of Bergerac Posts: 651 ![]() ![]() ![]() |
Thanks Kurt |
jon3929 Member Since: 01 Jan 2015 Location: Weston Super Mare Posts: 62 ![]() ![]() ![]() |
J90
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1847 ![]() ![]() |
I cut my own filter open (Disco 3 6 speed ZF) after 115k miles, and the strainer was clean too. It's not a filter as we think of filters ![]() The strainer is there to catch big lumps. If you have big lumps floating around your gearbox, you would certainly know about it ![]() It is advised by ZF, that the 6 speed and 8 speed boxes are FLUSHED between 50-75k miles. As said, I changed mine at 115k miles. It has just ticked over 150k miles now, and the gearbox is ![]() |
Jon3929, I changed my gearbox filter and oil at 56k. It did feel smoother and quicker as a result. I'm coming up to 70k now and will either have a 'flush' or another filter and partial oil change sometime before reaching 75k as further preventative maintenance. Travelling around in circles again. |
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 ![]() ![]() ![]() |
Hi jon3929, had my gearbox oil and filter changed at 119,000 mls, certainly made a difference, much smoother through the gears.
Thanks - I believe the gearbox is original.
