![]() | Home > Maintenance & Mods (L322) > Towbar Question |
martinf Member Since: 26 Dec 2014 Location: sussex Posts: 256 ![]() ![]() ![]() |
I will see what I can do |
devonchilliman Member Since: 06 Jan 2015 Location: Devon Posts: 348 ![]() ![]() ![]() |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3666 ![]() ![]() |
Also a great rear end protector |
[img]
Ahh,I see now |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8108 ![]() ![]() ![]() |
The hole for the bolt is also threaded for half the depth -
Thankyou,I understand now |
Towbar now fitted |
Sounds like my welding method sir |
Jamiehol Member Since: 26 Sep 2014 Location: Ipswich Posts: 230 ![]() ![]() ![]() |
13pin sockets are now fitted as the norm now, as the Caravan manufacturers have been using the 13pin plug as standard since about 2009, and even the trailer manufacturers are moving to them.
You wont regret the 13 pin set up, with an adapter it gives you the best all round options |
Actually, the reason that they are using 13 pin plugs is, all trailers made after September 2012 have to be fitted with reversing lights, and tested by VOSA or be type approved before you can use them on the road, and this is the law |
