![]() | Home > Technical (L322) > Door frame seal tear repair |
FrankRizzo Member Since: 27 Aug 2012 Location: Frankfurt am Main Posts: 222 ![]() ![]() ![]() |
I have a small tear in the front passenger side rubber door frame seal as shown. As it's only a small tear I'd like to repair it if I can rather than replace the seal. Can anyone recommend a suitable adhesive, i.e. one that won't dissolve the seal rubber?
Thanks for the reply. How long does the silicone take to set? My tear is on a vertical section and I don't want it to run to the bottom before it sets. 2012 Vogue 4.4 TDV8 automatic (LHD), Santorini Black
Just in case you decide to change it sir |
Swiftman Member Since: 23 Jan 2013 Location: Midlothian Posts: 128 ![]() ![]() ![]() |
silicon won't run down just put a bit masking tape or gaffer tape over repair & leave on overnight . |
