![]() | Home > Technical (L322) > 4.4v8 Oxygen sensors / Engine management light. |
| jim2RRs Member Since: 07 Feb 2012 Location: Genesee, Colorado Posts: 147
What Fisha said.
| KARMANN Member Since: 13 Dec 2010 Location: Scotland Posts: 95
Anybody?
| ebajema Member Since: 24 Mar 2011 Location: New Plymouth Posts: 4782
Sounds like someone already changed over the sensor connectors ??? Anyway, check the wiring first but it sounds like you have to replace at least the sensors on one side. As far as I am aware these sensors are not "fused" and the heating element is inside the sensor.
| fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1561
Sorry, missed the post. Don't understand the P-error, but the other data makes a bit of sense.
Thanks for the replies gents. Reset the faults and tried a genuine O2 sensor upstream of the cat on bank 2. It was then reading 0.430v and the fuel trim went to zero. But the fuel trim and V reading didnt move at all under revs or anything. Bank 1 still bouncing back and forth as normal. Switched the ignition off then restarted it within a minute the engine management light came on and engine start to feel rough again. Bank 2 still reading the same. Fault read as no activity detected.
| Gazellio @ Prestige Cars Member Since: 22 Jan 2010 Location: Chilterns, UK Posts: 11309
Gotta be worth a trip to the Indy I would say.... |
Ok so decided to trace the wires for the O2 sensor on bank 2 sensor 1. Traced it back to the ECUs in the front left of the engine bay. Whilst having a good look in there I found some 30amp fuses. Although they looked ok I decided to remove them and check continuety. One of them had blown, replaced this started the car and hey hoe not MIL light and no over fueling, connected compter up and getting bang on values for everything-Job done!!
| Winchester101 Member Since: 13 Jun 2013 Location: Essex Posts: 236
Hi guys I know this is a realy old thread but after getting the engine light on over the weekend and fault codes p154 p134
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8822
Good news mate, and a nice cheap fix.... wish all faults were just a blown fuse...!!! Pete
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35874
i wonder why the fuse blew Phil? ... - .- -.
I'm not sure Stan but Sunday from cold had to have the wheels spinning away from the house as a car was trying to kill me
