Home > Technical (L322) > To remove or not remove
Stormin
2003 Range Rover HSE Td6 Epsom Green
Talking to a friend last night who's blanked his EGR valve on his Jag 2.7 XJ
The question is, should I blank mine on my TD6, also he seems to think I'll need two kits if I do.
I have searched on here and quite a few have, does it really improve things or not ??
The old lump has clocked up 120k could I be encouraging trouble.
Thanks Three things in a blokes life his dog,his car and a Cornish pasty,nothing else matters.
2010 Range Rover Vogue SE Santorini Black, Arabica Aniline seats
Previous cars
1973 Mini 1000
1971 Hillman Avenger
1975 Chrysler Sunbeam
1981 Ford Cortina
1985 Volvo 340
1989 VW Golf
1989 Volvo 240
1991 Volvo 240
1991 Jaguar Soveriegn
1996 BMW 730
2003 Honda CRV
1999 Jaguar Soveriegn
2003 Range Rover HSE Epson Green with Sand trim.
Post #304474 12th Jan 2015 5:18pm
i did it on my td6 and it did improve mpg [slightly] and it felt more smoother...it only costs around £30 and is worth it...there's a how to in the wiki.. ... - .- -.
Post #304476 12th Jan 2015 5:20pm
J90
France 2006 Range Rover Vogue Td6 Java Black
Did mine. In full agreement with Stan. Travelling around in circles again.
Post #304479 12th Jan 2015 5:36pm
If you do blank the EGR, and I would recommend you do, can I suggest you keep the removed EGR valve, clean it up and put it in a box for possible future re-use. I have a suspicion that the MOT in the near future may require an EGR valve to be fitted if the vehicle originally had one, in a similar manner to catalytic convertors are treated now.
Post #304480 12th Jan 2015 5:38pm
Boydonegood
United Kingdom 2004 Range Rover Vogue Td6 Ipanema Sand
I have a high mileage 2004 TD6 and blanked mine off Friday just gone.
Only need one unit. Payed £28ish off Ebay. As Stan says there's a wiki on it and is real easy (20 mins to do). A screwdriver and 1 allenkey
My FF was already chipped, but this made a big difference performance wise when pulling away. Haven't noticed fuel economy yet mainly due to pulling away like an idiot while the novelty is still there! Wink
I didn't fit it for performance, I fitted it for the MPG gains reported.
Next for me is to fit a Green Cotton air filter.
Cheers
Tel Accept, some days your the pigeon, some days your the statue!
Post #304481 12th Jan 2015 5:41pm
Weegie
It would require removing parts to identify that it had been removed which isn't within the ambit of the MOT.
However, it is a good idea to retain the EGR as it may be that testing for NOX will become part of the MOT as it is the current "bogey man" for environmental issues.
I removed the EGR from my D2 and the next CT (MOT equivalent) showed lower tested emissions than with it. Smile
Have removed it from the FF but it came with a CT so haven't yet compared. John
GAP iiD BT-Sold
Post #304486 12th Jan 2015 6:09pm
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
If you want to give it a try, just pull the vacuum pipe off and plug it with a small bolt or similar, then tuck the pipe out the way, give a go for a week or so and see then weather you want to go ahead with the conversion. I'll bet you'll want to do it after. Thumbs Up
Post #304602 12th Jan 2015 11:10pm
