![]() | Home > Maintenance & Mods (L322) > Name that tune. Engine squeal sound. (Video attached) |
horse86 Member Since: 09 Dec 2014 Location: PA Posts: 863 ![]() ![]() ![]() |
So my Range makes a squeel sound. Or maybe a flutter is better description. It's not steady it will squeel for a second, then not for a second or two then do it again. I attached a video that tried to capture it. Is this a fan belt, tensioner, pulley, issue? I have a 90 day warranty from the LR dealer on engine and trans but it expires in a week or two so I need to know of this is something major.
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
Can't hear any squealing?? .
you don't hear it? Its like a fluttering or something rattling that's loose. |
Chirping does sound about accurate. It's intermittent and each instance is is not the same duration. I don't have a SC so possibly a belt. Hmmm. How hard/cost was it to switch the belt out? |
The oil leak was a warranty job and the belts were replaced within that process. I'm sure someone will give an indication as to parts and labour costs if the forum search engine doesn't help.
