Home > Technical (L322) > iidtool height adjustment
Where are you measuring from Stan, should measure from center of wheel to bottom of wheel arch, not from ground as that will vary due to tyre pressure, load in car, amount of petrol etc etc... basically anything that would change the depth of the tyres sidewall... Pete
Post #304517 12th Jan 2015 8:04pm
always measure from bottom of rim to top of wheel arch [the metal bit] ... - .- -.
Post #304519 12th Jan 2015 8:09pm
Yeah that'll work.... I can't bend down that low Rolling with laughter Rolling with laughter Pete
Post #304520 12th Jan 2015 8:11pm
Welshdragon
Wales 2003 Range Rover Vogue 4.4 V8 Monte Carlo Blue
and why not use the top of the rim instead..... it bit higher... Whistle Laughing If it dont work.......burn it!
If the IId tool cant fix it.......burn the FF.
If the FF cant be fixed......buy a Land Cruiser!
If the LC cant be fixed..............................................BUY a horse !!
Post #304527 12th Jan 2015 8:28pm
i'm sure there's a logical reason not to do it that way.. ... - .- -.
Post #304529 12th Jan 2015 8:30pm
measure from wheel centre stan, this removes any diameter issues with your rim Rolling with laughter (someone had too!)
seriously though.... .
Post #304546 12th Jan 2015 9:02pm
it wont affect the measurement on all four corners if i measure from the same position and as my heights are near to your 'chart' figures ,thats ok with me..
mine front 770, rear 760mm
Post #304562 12th Jan 2015 9:29pm
is there any way of defaulting the heights to the original OE spec? ... - .- -.
Post #305732 17th Jan 2015 9:20am
Mikey
I find it easiest to set the heights to the approx heights, then do a full calibration Thumbs Up
Post #305739 17th Jan 2015 9:59am
thanks mikey,
also going back to the 9mm tolerance, if both fronts are increased by a number will this tolerance be applied to both heights or is it possible that one will possibly get an extra 9mm and the other something else.. ... - .- -.
Post #305809 17th Jan 2015 1:56pm
Mikey
In a perfect world, all sensors would read 0mm
However, you have the tolerance of 9mm per side, so you can have +9mm on one side, and -9mm on the other. It doesn't matter what the calibrated values are, as long as they are within the limits of calibration
Post #305813 17th Jan 2015 2:25pm
