Home > Technical (L322) > Trans Failsafe Mode
aclr8r
United Kingdom 2009 Range Rover Westminster TDV8 Santorini Black
Trans Failsafe Mode
Hi All,
Have just had the trans failsafe mode kick in for the second time in 12 months. managed to get it plugged into 'all comms' with 'gear monitor 3 fault - general fault' showing up. On both occasions the failsafe mode kicked in after standing idle in traffic for sometime.
Would the above be a result of the gearbox overheating?
Would flushing the coolant system be a cure?
Many thanks in advance for anyone that can advise If you don't know what you're doing - do it quickly!
Post #304547 12th Jan 2015 9:05pm
"standing idle"
Is that in gear, foot on pedal, or in neutral, handbrake on, or in park?
Can you replicate on driveway? Try in different gearstick settings etc. (D or R or P) ?
Any problems with selecting P ? (so that it holds on a slope) .
Post #304561 12th Jan 2015 9:29pm
aclr8r
Handbrake off (useless piece of kit from my experience), in park.
Have tried to replicate with no luck.
No problems selecting P although appears slow to engage D from R 1st thing?
Holds well on slope in D and P.
Box was rebuilt 15k ago (before i bought it), battery replaced 6mths ago. If you don't know what you're doing - do it quickly!
Post #304691 13th Jan 2015 10:53am
Often a blocked lower section of the main radiator. The Gearbox Oil Cooler comes off the main rad after this section so its best to properly flush whole system concentrating on the Main radiator bottom section which may be fubarred.
Post #304693 13th Jan 2015 10:55am
aclr8r
Many thanks.
Looks like I know what i'll be doing this weekend.
Thumbs Up If you don't know what you're doing - do it quickly!
Post #304703 13th Jan 2015 11:15am
aclr8r
May not get to the weekend!
Just pulled up at the same set of traffic lights as before and the Censored jumped into failsafe again???(N with foot on brake). Pulled over, switched off and have managed to get into work.
Now thinking that it may be trans oil level? if it was over heating would it not give me a 'temperature fault' rather than 'trans failsafe'? If you don't know what you're doing - do it quickly!
Post #304931 14th Jan 2015 10:17am
i'd check the gearbox oil radiator for leaves etc like gary suggested and have a look at the battery/alternator as well.. ... - .- -.
Post #304932 14th Jan 2015 10:21am
aclr8r
Thanks for the response, I don't suppose that it could be the linkage?
I've read it on here that it can cause problems shifting between D and R. As I have the problem immediately after putting into D from sitting at junction from N position?
Just trying to look at all avenues Bow down If you don't know what you're doing - do it quickly!
Post #305029 14th Jan 2015 2:08pm
wouldnt do any harm to grease that up.. ... - .- -.
Post #305044 14th Jan 2015 3:01pm
snigger fnar fnar Laughing .
Post #305110 14th Jan 2015 7:45pm
aclr8r
I have a tube of lube ready for the weekend. i'll ask SWMBO to give me a hand or i'll just use it on the FF Mr. Green If you don't know what you're doing - do it quickly!
Post #305277 15th Jan 2015 2:42pm
Laughing ... - .- -.
Post #305280 15th Jan 2015 2:45pm
aclr8r
UPDATE
Quick update on progress on the TFS gremlin:
1) Taken to transmission specialist and fault cleared once more (gear 3 general fault), said it meant that it was slipping in 3rd. Sadly their auto box specialist has passed away and they're no longer doing autos.
2) Oil levels checked and quality fine
3) Linkages checked and lubed (SWMBO did not want to take part Sad )
4) Battery replaced with Bosch S5 (had the hdc appearing the last few cold mornings on start up, so battery was on its way out obviously)
5) Booked in with the local Bosch Auto-service centre to undergo a full coolant power flush this week.
Does appear to be running better since 1-4 above but now I'm listening out for all sorts of things (even have the radio switched off for the first time). I'm getting paranoid Exclamation If you don't know what you're doing - do it quickly!
Post #306491 20th Jan 2015 2:57pm
aclr8r
Further Update
Sadly Crying or Very sad no positive response to all of my fumblings so having her seen to by a specialist that will give her the deserved internal inspection.
Apologies: I must point out that this is the FF and not SWMBO. After her refusal to help out with the lube last weekend she's not deserved any inspections Rolling with laughter
Will update when returned with a new recon box and their findings. If you don't know what you're doing - do it quickly!
Post #308744 28th Jan 2015 3:15pm
ebajema
What is the mileage on your car ?? It is of an age where the box may be past its prime. MY 2010 5.0 SC Galway green and sand interior!!
Post #308746 28th Jan 2015 3:19pm
