Home > In Car Electronics (L322) > Range Rover L322 key fobs
scwilson
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Epsom Green
Folks,
I bought the RR in my signature early December last year, it came with 3 remote control fobs. Two appear OK but the third is very tatty and the rubber is split on the main lock button.
My questions are;
1. Can I buy a new outer case/fob for it and just re-fit the electronic bit inside? I am presuming not and will require the key to be cut and this is not removable?
2. Where can I buy replacement screws and the screw cover for the back of the fob? Each fob has two screws and the head on most of them are almost gone.
Thanks in advance!
Post #304530 12th Jan 2015 8:37pm
fancy a read? Wink
http://www.fullfatrr.com/forum/search.php?...rch_time=0 ... - .- -.
Post #304533 12th Jan 2015 8:42pm
zoso
Scotland 2013 Range Rover Autobiography SDV8 Santorini Black
Hi
I had the same issue and sent my dodgy one to these guys........
http://www.ebay.co.uk/itm/Repair-Service-F...c889a1e4a[
Did an excellent job although you'll need to program the key when they return it - 2 minute job.
cheers 2017 4.4 TDV8 Autobiography
2016 4.4 TDV8 Autobiography - GONE
2013 4.4 TDV8 Autobiography - GONE
2010 3.6 TDV8 - GONE
2008 3.6 TDV8 - GONE
2002 3.0 TD6 - GONE
2006 Discovery 3 TDV6 S - GONE
2006 Discovery 3 TDV6 - GONE
2003 Discovery 2 TD5 - GONE
1999 Discovery 300 TDI - GONE
1998 Range Rover DSE - GONE
1997 Discovery 300 TDI - GONE
Post #304589 12th Jan 2015 10:57pm
Ianmaney
United Kingdom 2011 Range Rover Vogue SE TDV8 Mariana Black
Ive been looking at getting these done, my question is, how do you re program the key once it's back??
Post #304908 14th Jan 2015 6:54am
zoso
There are quite a few posts on here about how to programme the key fobs. The guys that did mine also sent me a procedure on what to do - it only involves a sequence of button presses on the new remote to link it to the car. Once you've done the new one you need to reprogramme the existing fob also.
2002 3.0 TD6 - GONE
Post #304926 14th Jan 2015 9:29am
scwilson
From the web ...
Programming a new Key
Replacing a missing master key is quite expensive from Land Rover, try not to get sucked into the extra cost of "Dealer coding" You can do this yourself in 2 minutes by following the simple process below.
1) Get in and close all doors. Turn ignition on and off quickly and remove the key (all within about 5 seconds).
2) Within 30 seconds of turning the ignition off, while holding down the "unlock" button, press the "lock" button three times. Release the "unlock" button. (You may or may not get the confirmation from the door locks.) Holding the key at your head level provides best results as the key sensor is in the side window pillar.
3) Repeat for each key you want to initialize within 30 seconds after the last one you initialized (if you have more).
4) Right after doing the last key, quickly put the key back in the ignition and turn it on/off again to finalize.
I used the above procedure on my two keys when I changed batteries and it works.
Post #304954 14th Jan 2015 11:34am
on the forum as well,
http://www.fullfatrr.com/forum/topic3713.h...amming+key ... - .- -.
Post #304970 14th Jan 2015 12:06pm
Ianmaney
Nice one, thank you, I'll be getting one ordered in the next week or so Thumbs Up
Post #305198 15th Jan 2015 8:30am
Pilgrimmick
Scotland 2004 Range Rover Vogue Td6 Java Black
What would the problem with using one of these be?
eBay item no eBay Item No. 141915308532 Got enemies? Good, you have stood up for something in your life.
Never regret growing old, it is a privilege denied to many.
Post #376890 11th Mar 2016 5:37pm
sheps
hi,
i just brought a pair of these, all you need to do is swap over your insides and get the blank cut
http://www.ebay.co.uk/itm/131342489861?_tr...EBIDX%3AIT
cheers alex
Post #379727 28th Mar 2016 9:26am
johnboyairey
Just observe the tiny piece of black plastic and its position, as you open up the key. Don't lose it, it is the brain of the key. The circuit board is the mechanics. The pice is only about 10mm long and is sort of triangular from memory. It looks like a broken shard of 'old key shell' it isn't, it's the unique piece and necessary of key to change over.
Post #379730 28th Mar 2016 9:39am
