![]() | Home > Technical (L322) > Dreaded Flat Battery |
Fish Member Since: 30 Aug 2014 Location: Bolton Posts: 301 ![]() ![]() ![]() |
Thanks, I did wonder about that. Does it unplug in the boot on the right hand side?
I'm not sure if it did any damage to harness but was going to change from 7pin to 13pin whilst doing it. I presume the harness runs through the body in a grommet or similar somewhere. |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3987 ![]() ![]() ![]() |
The cable harness from the socket goes into the car via a large rectangular grommet just behind and above the sockets, behind the bumper. You can see it from underneath. The large grommet is presumably to fill the hole needed to get the plug end of the harness into the car.
Cheers.
I've been monitoring the battery level and have just tested it now. I opened the doors and the bonnet and checked it and it read 11.74v. I left it 30mins or so for everything to switch off and it went up to 12.1v
12.1v after the car has gone to sleep again after opening is definitely too low to be of any use and indicates a battery charge level of about 50%. Freezing weather does drop the battery voltage a bit but only in the order of 0.1 to 0.15V.
Thanks, I'll double check all the connections and do a recondition charge on the battery then check it again. |
cvp Member Since: 05 Oct 2014 Location: Los Angeles (Soulless central) Posts: 2 ![]() ![]() ![]() |
I'm also hunting down a strange charging/battery issue on my 2010 FFRR 5.0L.
Device available In the UK :
Latest update
Update on mine:
sass Member Since: 23 Apr 2014 Location: Helsinki Posts: 41 ![]() ![]() ![]() |
I didn’t want to start a new thread just for my woes with the parasitic drain, so I’ll post here:
Guys!
I replaced the towing sockets for a 13 pin one today and wonder if this was in fact the problem following the melting incident. Since I did a recon with the ctek and unplugged the towing loom it's been fine. This is what I found today. I had to cut the plug off as the screws on the connectors had rusted.
