![]() | Home > Technical (L322) > Instruments |
Andy3681 Member Since: 13 Jan 2012 Location: Newcastle under lyme/ Le Dorat Haute Vienne Posts: 912 ![]() ![]() ![]() |
Advice please team, I am not sure if this should be in technical electronic or maintenance treads so start here.
SMUTT Member Since: 30 Jun 2014 Location: Cheshire Posts: 459 ![]() ![]() ![]() |
Hi Andy. You really have had a run of bad luck lately.
Hi
Bump.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8723 ![]() ![]() ![]() |
These folk are one of the leading repairers...
Thought about the battery I have given it a good charge, it didn't seem to make any difference but the fault is intermittent, only other issue is air suspension warning coming on and off. If I look at off road screen while the message is on all four wheels show the little red icons are at the bottom of the wheels then after a few minutes it goes back to normal with icons in their normal position? Mine was a blue one! |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8064 ![]() ![]() ![]() |
Mine seemed to charge ok, but a proper battery tester showed it as defective.
