Home > In Car Electronics (L322) > USB file format help
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
Morning all,
Still playing with my new toy (can you tell I'm smitten with it?)
Just copied a load of songs from my iTunes library onto a usb stick and tried it in the USB slot (inside the centre cubby box). The stick reads ok - well the screen says reading.. but then always comes back with device error.
Is there a certain format I need to store the files in or a certain folder that they all need to be in for the system to read/play correctly..?
Thanks Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #306036 18th Jan 2015 12:34pm
Andy B
Hi Ash,
A load of useful info here :-
http://www.fullfatrr.com/forum/topic29293.html?highlight=mp3
Cheers,
Andy SDV8 AB MY 2019
SDV8 VSE MY 2015 - Gone
5.0 S/C AB MY 2010 - Gone
4.2 S/C VSE MY 2006 - Gone
Post #306037 18th Jan 2015 12:37pm
SKOT
England 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
Have you copied the files directly to the stick or do they report into folder(s)?
The latter is worth trying as some systems look for a root folder first and then the files. 2006 4.2 SC
2019 Renault Zoe Dynamique Nav
Post #306038 18th Jan 2015 12:37pm
comports
As always you gents are super...
Yes - have put a few in a single folder (80s music Razz )
will have a look at the formatting next - it's on a mac so maybe the wrong format..! Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #306041 18th Jan 2015 12:47pm
SKOT
Apple may be a problem. I would reformat the stick via Windows. Also check how many files you have in any one folder. It may be sensitive to that.... 2006 4.2 SC
Post #306043 18th Jan 2015 12:49pm
comports
firing up VMware as I type.... Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #306045 18th Jan 2015 12:57pm
Start with FAT or preferably FAT32 format, should be readable by just about everything, if not try NTFS. But then after that it may be the folder issue thats causing the problem. .
Post #306047 18th Jan 2015 1:07pm
comports
No Joy - Windoz and Mac just don't play nicely with each other. Mac will format the drive but keeps adding the .Trashes hidden folder...
Windoz just says it can't format the drive (cos it's inferior)..!!!
never mind - I'll just have to hunt down the official iPod connector.
thx anyway Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #306050 18th Jan 2015 1:23pm
