Home > Technical (L322) > 2004 4.4 FFRR - Heated Windscreen Fault advice needed
Knightrider
Hi Guys the heated windscreen on my Range Rover is only defrosting/working on the passenger 1/2 of the screen. It clears the passenger 1/2 completely but doesn't do anything to the drivers side. Does anyone have any idea about how I go about repairing this issue and what I need to look at or check?
Thanks in advance for any advice. 2004 Range Rover Vogue 4.4 v8 LPG, Java Black, 22' Hawke Alloys, Black Beast
Post #306228 19th Jan 2015 1:59am
espaceboy
take the a-pillar trim off on the affected side and check for 12v+ when you activate the screen
Measure at the flex connection to earth. there is also a wiper are heater flex worth checking too
the good news will be if you don't get 12+ volt
else the screen is damaged and must be replaced
Post #306370 19th Jan 2015 8:39pm
Knightrider
Hi thanks for the info, any idea of how I go about taking the A pillar trim off without damaging it?
I'm hoping it's a faulty connection as you can literally see a divide right down the centre of the screen where one 1/2 is working and the other side isn't. 2004 Range Rover Vogue 4.4 v8 LPG, Java Black, 22' Hawke Alloys, Black Beast
Post #306508 20th Jan 2015 4:15pm
Welshdragon
Wales 2003 Range Rover Vogue 4.4 V8 Monte Carlo Blue
I would hazard a good guess you might need a new screen, they do De laminate and the small wires brake up. I suspected mine was not working the other day when we had a heavy frost, took ages to clear, but on a light frost it cleared it Confused .
The air bag badge is a tight fit.
Joe90 reply on here
http://www.fullfatrr.com/forum/topic29337.html If it dont work.......burn it!
If the IId tool cant fix it.......burn the FF.
If the FF cant be fixed......buy a Land Cruiser!
If the LC cant be fixed..............................................BUY a horse !!
Post #306511 20th Jan 2015 4:23pm
