![]() | Home > Technical (L322) > Early EAS, Has anyone cracked the slow to lift symptoms? |
The early L322 takes it's time 'settling in' (the suspension height light continues blinking), but the actual height changes happen just as quickly on my TD6 as with my TDV8. I can use the manual valve control in the IIDTool or change heights via the knob/buttons in the vehicle. The height 'jump' is more or less the same - providing the reservoir is full. There is no difference in line diameters or reservoir. And, tho I've never compared directly, but I don't believe the valves in the 06> are going to be more restrictive than in the early L322. A single change up (access to standard or standard to off-road) should be more or less covered by the volume in the reservoir. So unless you do multiple height changes in a row or go from access to off-road, the compressor should not even play that great a role - except, possibly, when the car is 'settling in' and making final adjustments. This does seem to take longer on the early L322 than on the later, but I believe that this is down to programming. Miggit, if you're waiting for the RR to actually come up rather than just 'settling in', I'd think you may have an issue. It does not sound like the norm. There are numerous ideas floating around the inter web on modifying the EAS for more air, to function faster (mexican car dancing?), inflating tires that have been aired down for off-road, etc. Realizing a working idea is not as easy as it seems at first glance tho - at least not if you want to keep the system halfway reliable. That means air in and out through the drier, not many addtl (leaking) connectors, etc. ![]() RRC 2Dr, RRC 4Dr, P38, and 2 L322s (wife thinks I'm nuts - prob right, too) |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3665 ![]() ![]() |
Hi Steve, my 'ang' 'over, when poised to jump in to a waiting hitch, sort of goes like this. I leave the tailgate open to delay all until I can get to the catch on the hitch, so with high selected and tailgate and all doors shut, it will pause for a couple of seconds and then quickly rise about an inch (25mm as I believe you are metric |
From what height to what height are you going?
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8767 ![]() ![]() ![]() |
Steve, mine stops using air from the tank when the pressure drops to around 140PSI, surely there must be more left to fill the bags some more..... Pete
Hmmm, you've got me thinking Pete, |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3982 ![]() ![]() ![]() |
I don't think you can compare the airbags with a tyre for lifting capabilities, I think airbags are more akin to air operated pistons in so far as the air is only usefully providing lift force to the top and bottom of the airbags the sidewall merely contain the air as a cylinder would.
All of which is why I asked on the height changes: Miggit - from what height to what are you usually going?
Right Steve, I'm going from normal to offroad, and it all seems fine for the first inch and then everything gets rather slow |
Miggit,
I have all the time in the world, while I wait for my car to rise |
