Home > Technical (L322) > Surging idle
RRBlue
England 2005 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
Surging idle
I have noticed that my 4.2sc is surging whilst idling. It is a repeated rhythmic surge of approx a few hundred rpm. Whilst not alarming, it did not do this until recently and has coincided with the car cutting out after starting it up cold. Any thoughts? 2014 5.0 L405 Supercharged Autobiography & 2015 3.0SDV6 HSE Lux Discovery 4
2005 4.2 L322 Supercharged Vogue SE & 2011 3.0SDV6 HSE Discovery 4
2002 4.4 Vogue
2000 4.6 Vogue
2010 Freelander 2 TD4 HSE
2009 Freelander 2 TD4.e 2009
1992 Mercedes 300D
1986 Renault 2.1 Turbo D
1976 Morris Marina 1.8
Post #306125 18th Jan 2015 6:27pm
Usually a leak into the inlet manifold, car measures air going in and adjusts fuel accordingly, leak lets in too much air and effects the tickover..... check all hoses including the vacuum ones... Pete
-Click here for Thread-
Post #306146 18th Jan 2015 7:46pm
ebajema
Mine did that as well before we changed the fuel pump and cleaned the inlet tract. Could indeed be false air as well. MY 2010 5.0 SC Galway green and sand interior!!
Post #306233 19th Jan 2015 3:25am
RRBlue
Makes sense. I will do the necessary checks. Dreading fiddly vacuum hoses!
Many thanks. 2014 5.0 L405 Supercharged Autobiography & 2015 3.0SDV6 HSE Lux Discovery 4
2002 4.4 Vogue
2000 4.6 Vogue
1992 Mercedes 300D
Post #306356 19th Jan 2015 7:40pm
RRBlue
I gave the MAF sensor a good wash with the special MAF sensor cleaner spray. No immediate change, but next day she fired up just like she used to and U.S. Idling smoother.
Very simple procedure and good result.
2002 4.4 Vogue
2000 4.6 Vogue
1992 Mercedes 300D
Post #308184 26th Jan 2015 2:27pm
