Home > Technical (L322) > [SOLVED] One Touch windows
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
Before you all shout at me I have RTFM and can find no reference to it.
My windows go down fine with the one touch feature but they will not go up with it.
On my old one I used to be able raise it fully and hold the button for a few seconds then fully open and continue to hold for a few seconds. That would reset them for the one touch operation.
Maybe that's not how it works now so any clues would be most welcome.
Ta muchly Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #306365 19th Jan 2015 9:25pm
That's how it works on my disco...... Close window and hold for 10 secs. There is nothing that can't be fixed with a hammer😜😜
Post #306368 19th Jan 2015 9:30pm
i think you can activate it with the iidtool Ash.. ... - .- -.
Post #306374 19th Jan 2015 9:42pm
comports
Hmm - need to get a new IID me thinks - my IID is for my old 54 plate.
Note to self, sell my old one on here to purchase a new one for my model year. Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #306377 19th Jan 2015 9:49pm
JAYBOY
Send the window down and hold the button for about 10secs. send the window up and hold for the same time.
repeat if it didn't work the first time.
Thats what i did with mine. Works ok now Thumbs Up 2020 Porsche Panamera Turbo Hybrid (V FAST)
2018 JCW Mini Cooper
2018 Skoda VRS
Post #306383 19th Jan 2015 10:04pm
comports
Thanks Jay
maybe and extended, extended press and hold is what I need to do..
Will try that tomorrow.
cheers Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #306387 19th Jan 2015 10:11pm
IanV8
Scotland 2011 Range Rover Vogue SE TDV8 Santorini Black
Only works with the engine running.
Ian
Post #306466 20th Jan 2015 11:36am
comports
Update - I found the details on the RRSPORT site.
I tried this today on my way to work so engine was running (but not sure if this is necessary)
Worked perfectly..
Quote:
Resetting one touch operation
If the battery is disconnected, becomes discharged or the power supply is interrupted, the one touch up window operation is disabled until the window position is reset.
To reset the window position:
1. Close the window fully
2. Release the switch, then pull up and hold the switch for one second.
3. Repeat the procedure on each window.
Thumbs Up Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #306688 21st Jan 2015 11:27am
