Home > Maintenance & Mods (L322) > Check your waterworks
After reading a post by Alistair, I went and had a look at the expansion tank hose, the one on the bottom feeding into the system not the top bleed one.
He mentioned that his had been chafing on a bolt head and had blown, mine on the other hand has been rubbing on part f the wiring loom and has started to wear through. It is not terminal at the moment but needs a bit of tape round it for protection.
It's worth a look on the tdv8's takes 5 mins to check and could save a few quids as apparently it only comes as part of the full hose kit at ££. There is nothing that can't be fixed with a hammer😜😜
Last edited by northernmonkeyjones on 19th Jan 2015 10:46pm. Edited 1 time in total
Post #306343 19th Jan 2015 7:38pm
The hose isn't available individually from LR - only as part of a set that even Dan couldn't get below £200 - http://www.fullfatrr.com/forum/topic28094.html
In the end I used a generic bit of hose - I can't remember exactly, but I think it was 19mm
Post #306381 19th Jan 2015 9:54pm
That's the one quick bit of tape has stopped mine going so Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #306384 19th Jan 2015 10:05pm
It's hard to see under the tank -
but once it's removed, it's the pipe from the centre of the picture to bottom left -
This is the other end -
and this is what it looked like underneath -
An easy fix in daylight, but mine went late at night on a french motorway - I noticed the pool of coolant in a service station - it drank a lot of water that night - I had to stop about every 45 minutes Smile
Post #306385 19th Jan 2015 10:06pm
Managed to get hold of the entire hose set of eBay for £59. Will go on the jobs to do list when it arrives! There is nothing that can't be fixed with a hammer😜😜
Post #306852 21st Jan 2015 8:22pm
