Home > Maintenance & Mods (L322) > Towbar Question
Page 4 of 5 <12345>
devonchilliman
United Kingdom 2011 Range Rover Vogue SE TDV8 Santorini Black
Used the motor to tow yesterday for the first time and I'm not a happy bunny Big Cry Big Cry
There's so much play in it the noise of it clonking and bonking is unacceptable...
Anybody else experienced this ?
Post #306524 20th Jan 2015 6:36pm
Jamiehol
United Kingdom 2007 Range Rover Vogue TDV8 Stornoway Grey
Yes I noticed this the first time I used the FF to tow my Ifor Williams car transporter, I found it was worse unladen, also my tow ball was a bit too low which made the situation worse.
The only way to remove completely would be to bolt it in, or may the tow bar bit a tighter fit in the receiver.
Post #306533 20th Jan 2015 6:54pm
Yep, can be noisy. Mine has the detachable hitch, so it's not play in the bar.
It's a toss up, its dead quiet with the caravan as it has an alko hitch stabiliser, but when I put the trailer on it is very noisy, but then again there is no grease on the ball as it needs to be clean for the caravan, which would probably help somewhat.
Funny because it's not noisy with the disco... I wonder if the ball is a little smaller by a mm so has a bit of slop. As has been said is much better with 150kg on the nose. My trailer has a very low nose weight unladen maybe even negative.... There is nothing that can't be fixed with a hammer😜😜
Post #306540 20th Jan 2015 7:12pm
devonchilliman
The problem is where the so called removable part slots into the receiver it is so loose it moves up/down and left to right,I have spoken to the dealers and I'm thinking of having the 2 parts welded to stop it Thumbs Up
Post #306541 20th Jan 2015 7:17pm
devonchilliman
You can see in this pic just how much of a gap there is Whistle
Post #306543 20th Jan 2015 7:25pm
Vogue
I have had the same on several L323's - now I just push a business card into the slot - it takes up the freeplay, its simple, it works and you can still remove the towbar. Don't weld it you will ruin the towbar and if there is an accident it could be blamed... 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #306560 20th Jan 2015 8:54pm
Tap a couple of plastic building packers tight into the slots. Will take up the slack and won't go soggy Thumbs Up
I Have loads of them around on site and can post a few assorted ones out to you if you PM me your address. There is nothing that can't be fixed with a hammer😜😜
Post #306574 20th Jan 2015 9:32pm
martinf
United Kingdom 2016 Range Rover Vogue TDV6 Santorini Black
This is precisely why I recommended the tow bar with the bolt fitting earlier in this thread. I had the same problem.
Post #306577 20th Jan 2015 9:44pm
Laughing Yep - we all have - you asked for the advice, then ignored it........
Post #306589 20th Jan 2015 10:24pm
supershuttle
I always take the view that if the rattling stops I must have forgotten to put the pin in before I set off Rolling with laughter Geoff
Post #306605 20th Jan 2015 11:22pm
miggit
I find that I can concentrate on where I'm going as long as there is a rattle from the back, the second that I hit smooth road, which doesn't happen a lot now a days, I'm looking more in the rear view mirror to see if everything is still there Shocked
I will admit that it can be more than annoying if the trailer has little or no nose weight, I find that the nearer to the max nose weight the quieter it gets, and if your pulling a multi axle set up then it really needs to be level or slightly high at the nose. If it's low at the nose it will preload the front axle of the trailer and cause the trailer to lift the rear of the car, lots of knocking noise and a trailer all over the road. The only exception to this is twin axle set up on leaf springs, as the tandem link balances the weight on each axle regardless of the nose height.
And you are right the L/R hitch height is a little on the low side, especially if you've a twin axle 'Indespencion' setup. If you have the height adjustable hitch you should be able to get around this, if you have the swan neck, Whistle good luck! Yesterday I couldn't spell Engineer... Today I are one!
Post #306611 20th Jan 2015 11:50pm
devonchilliman
Wink didn't ignore it,just had to go with the Stealers advice till I got home ,as I was told that would void the warranty Rolling Eyes
@northernmonkeyjones...thanks for that idea,I think I might have something like that kicking around in the garage Thumbs Up ,if not I may take you up on your offer Thumbs Up thanks
Post #306619 21st Jan 2015 12:13am
miggit
If you get stuck try these
http://www.toolstation.com/shop/p46640
Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #306627 21st Jan 2015 12:27am
supershuttle
It's also a good use for old credit cards - don't tell me it's not just me that keeps them. Very Happy Geoff
Post #306629 21st Jan 2015 12:33am
miggit
Hey Chap, why not save yourself some dosh and just use the wife's current cards Rolling with laughter Yesterday I couldn't spell Engineer... Today I are one!
Post #306632 21st Jan 2015 12:37am
Page 4 of 5 <12345>
