![]() | Home > Technical (L322) > ventilation closing |
| TerryT-J Member Since: 02 Sep 2013 Location: Johnston, Pembrokeshire Posts: 86
I've got a problem that after driving for about an hour, all ventilation into the car shuts down. All controls work fine before that. The fan can be heard when on full but a slight whistling as the air tries to get out somewhere. I'vtried with the pollen filter in, out and upside down if it was put in the wrong way last service. If the car is left off for about half an hour all seems to be back to normal - unless going on a journey for an hour our more. Could it be the HVAC resistor failing? I was thinking it is overheating/breaking down over timeshutting the stepper motors down. Ta, Terry. |
| mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8001
I think the resistor pack, or FSR just controls the fan speed, so won't affect the vents opening etc.
Fan speed works fine even when vents seem to be closed. It just seems strange that everything works as it should, then the airflow itself seems to get blocked off after an hour or so's driving. I dont have access to a fault reader (one day!) and don't really want to go to the main stealer! |
I first noticed it last summer whilst travelling through Germany and it getting bloody warm inside the car! The only way to let any air in was to crack open a window and tilt the sun roof! As a foot note this was the same trip when the gearbox packed up in Switzerland! That aside, using the vent/temp controls don't seem to make any difference, it will still cut off outside and recirc air after about an hour. |
| nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3989
In that case it appears you have a problem.
| All times are GMT |
