![]() | Home > Wheels & Tyres > French recommendations on fitting snow chains ... |
bebechoon Member Since: 22 Apr 2014 Location: In ze middle of Frainsch nul part Posts: 455 ![]() ![]() |
In an article entitled “All you need to know about snow chains” (my translation) published in this week’s AutoPlus – a popular weekly French motoring magazine – they give the following advice for 4WD cars (again, my translation):
The centre diff is (I think) a torsen diff, so does limit slip which is why Land Rover say fronts only for chains - it should mean torque to all four wheels even if only the front two have grip. |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3271 ![]() ![]() ![]() |
Kurt,
Ok, but my point was you fit them only to one axle and the centre diff will take care of it. |
I understood the point in the French article was that, if you only fit chains to one axle – without a locking diff – the spinning-uncontrollably, non-chained wheels/axles will make the diff work hugely overtime and result in its early demise …
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8111 ![]() ![]() ![]() |
They won't fit on the front of a FFRR with 20's - there just isn't enough room past the damper - you need more than a few mm - more like 20+ and even then I'd be concerned about them losing a bit of tension & flapping..... |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8776 ![]() ![]() ![]() |
You are correct, There is only about a fingers width so, no you won't get decent chains on the front with 20". No probs on the back though which is all I will need👍 There is nothing that can't be fixed with a hammer😜😜
CSK Member Since: 15 Oct 2010 Location: St Tropez Posts: 750 ![]() ![]() ![]() |
There's a snow traction system sold by Land Rover as an accessory. On L322 it is to be fitted on the front wheels only. On the L405 at the back. |
noworries4x4 Member Since: 03 Oct 2013 Location: Newton Abbot Posts: 166 ![]() ![]() ![]() |
I exploded a front cv joint in France on my P38 a few years back stripped it all out and drove home towing the tri axle with the Bowler on it no trouble the viscous diff locked up and drove me home. I thought I was going to be in deep pop poo but no worries. I kept stopping and put a hand on the diff to see if it was getting hot but no dramas.
Going to try the chains on the 20", not sure if they will fit as they are for 255/55 19 amongst other sizes. Can't see why not as the rolling radius and cross section is the same so the bit they are fitting on is the same! But it doesn't say 255/50 20 on the packet for some reason.
