![]() | Home > Maintenance & Mods (L322) > C TEK |
J evro Member Since: 31 Aug 2014 Location: Kent Posts: 541 ![]() ![]() ![]() |
Help!.....bought the Ctek7 last week ,was planning to connect it up tonight but I've lost the instructions I have the cig lighter adaptor and live feed accessory socket in rear,
Nomad Member Since: 26 Oct 2011 Location: Ringwood, Hants Posts: 300 ![]() ![]() ![]() |
Normal for normal battery. Snow flake setting for AGM battery. |
Sorry Nomad was editing my post to add piccie when you replied ,
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8760 ![]() ![]() ![]() |
looking at the manual Normal, AGM, Recond all seem to go to pulse as stage 8. Seems to hold step 7, float upto 10 days then goes to pulse if i understand what they are saying correctly.....
Steverr Member Since: 27 Oct 2013 Location: Bristol Posts: 191 ![]() ![]() ![]() |
How often would you recommend connecting the charger ? Every night, every week or once a month ?? Thanks in advance |
All depends on how often you do not use your FF , glad to report I've just been away for a month and had it on pulse mode whilst away and returned to a fully charged battery and started straight away ( should have bought one years ago ) |
Which one did you get ? The 5.0 or 7.0 ?? Plugged in the 12v socket in the luggage compartment ? |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3927 ![]() ![]() ![]() |
I don't use a Martin one as I didn't spot them until I had bought all the bits and made one myself - if wish I had seen Martins sooner as it would have saved me time and trouble |
I have the 7.0 and just plug it onto the rear 12v socket |
