![]() | Home > In Car Electronics (L322) > Headlight Delay |
Pull back the headlight flash after engine off - should stay on for 20-30 seconds. If you DON'T have auto lights then this should happen automagically |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3951 ![]() ![]() ![]() |
With my old one I found that a quick flash of the headlights was needed. Geoff |
With your lights on "auto" take the keys out... Flash the full beam and "hay presto" headlight delay |
noworries4x4 Member Since: 03 Oct 2013 Location: Newton Abbot Posts: 166 ![]() ![]() ![]() |
Ahh that might be the problem then, as the sharp eyed among you might have noticed one of my other posts my screen wiper and light sensor is broken waiting to order a new one from Dan but also trying to get some 3M to stick it on with, bloody autoglass used silicone. If everything is under control you are not going fast enough.
