![]() | Home > Maintenance & Mods (L322) > What components should heat up and defrost when icy? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35766 ![]() ![]() |
side windows arnt heated , thats the diverse antenna's there..
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1901 ![]() ![]() ![]() |
One morning I though the front screen wasn't working as it took a long time to defrost but on a light frost it worked fairly quick, door mirrors work fine and clear very quick to clear as does rear screen.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
Pass mirror glass is probably U.S. sir |
scwilson Member Since: 15 Dec 2014 Location: Dorset Posts: 240 ![]() ![]() ![]() |
oh ok that explains the side rear windows then, I saw what I thought was a heater element but as you say, it's actually an antenna, good to know.
They are ignition fed at that age, so on permanently |
@ Craig, when did they change then? Are you saying the facelift 06> are now switch fed and not on all the time....seem to be a backward step imo. If it dont work.......burn it!
Sorry for my lack of knowledge here but what does this mean? |
Un Serviceable sir... |
No no, they have always been ignition fed ![]() Stops them misting up in cold weather when travelling |
