![]() | Home > Maintenance & Mods (L322) > Front Mud Guards not quite flush to bodywork |
n1cktdv8 Member Since: 19 Aug 2013 Location: Cheshire Posts: 1754 ![]() ![]() |
2 words...
scwilson Member Since: 15 Dec 2014 Location: Dorset Posts: 240 ![]() ![]() ![]() |
I didn't think of that |
You may need to take it off and try again. Its only a lighweight panel and need to be located exactly to look right but can easily be moved about using finger power. Silicone NO |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35766 ![]() ![]() |
they look like they need to come down vertically a touch so the profile fits better.. ... - .- -.
FFS....it was a joke... ![]() |
Not sure they can come down any lower as the holes were already cut in the panel (perfect alignment with the Land Rover template) and the brackets already in place. The panel is so flimsy I worry about breaking it or any of the flimsy plastic brackets on the back of it. I spent a while yesterday trying to adjust to no avail |
One option I have is to remove the old brackets and fit the new ones supplied with the mud guards. I didn't bother fitting the new ones since the old ones were in place already.
i've been looking for front mudflaps and i've noticed that there are two different types of mounting brackets , maybe you need to swop yours? ... - .- -.
Mine were from Land Rover themselves. The brackets that were already on my RR aligned with the holes so I assume if there were any changes in the brackets it would have been highly noticeable.
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3241 ![]() ![]() ![]() |
Mine are just like yours, with a slight bend away from the bodywork. Think it is more to do with the plastic warping. Hair-dryer may do the trick. |
Are OK, weird isn't it?
have you put 2 bolts in where i've marked with arrows?
Yes, there are two bolts that fix to the removable plastic panel.
