![]() | Home > Maintenance & Mods (L322) > Front Mud Guards not quite flush to bodywork |
| Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947
Don't put screws in if you ever want to remove them though |
| scwilson Member Since: 15 Dec 2014 Location: Dorset Posts: 240
Do you mean rusting and the heads coming off? |
No if you use screws these are secured by drilling into plastic panel . Once removed (flaps) you will have holes in the panel. I fitted flaps thinking the car looked best with them but on reflection I prefer no flaps but it proved too late as I had drilled holes. If you must have them leave them fitted as they are that way should you ever want to remove them you wont have any holes to cover up. Present :2008 TDV8 HSE
Ok resolved. Took both off, fitted some number plate double side tape inside the mud guard to hold to the bodywork.
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35874
good job sir |
| PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1263
Must admit, was thinking of fitting them to mine but I dont like them with the two white arrows on!! Can you get them without?? |
| Ianmaney Member Since: 27 Nov 2012 Location: Birmingham UK Posts: 118
Its built by Land Rover, its supposed to have gaps !!!! |
| Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16403
