Home > Technical (L322) > Heated seat
Squirrel
United Kingdom 2009 Range Rover Autobiography 5.0 SC V8 Galway Green
Heated seat
My driver's side heated seat has given up the ghost. Sad
Any ideas on where to start with fixing it? When you switch it on, the light comes on for a few moments and then goes off again.
It started not working directly after LR had had the car in to replace the plastic switch panel on the side of the seat - they broke it while it was in with them for some work and tried to stick it together, but it was properly broken and kept coming off so I got them to replace it. This might not be related, but it could be so I thought I'd mention it!
I've had a couple of people look at it (one LR, one indie), and both have said it "might" be the heating element. Does this sound feasible? If it is then I don't mind coughing up and buying a new one - I don't like having a cold backside in the mornings. Very Happy But if it's going to be something else then there's no point in paying so much,
So anyway. Has anyone else encountered this problem, and if so how did you fix it? And are there any cheaper things I could test before I spend lots of money on a new element?
Thanks in advance. Smile
Post #308665 28th Jan 2015 9:48am
Your seat is showing the common symptoms of a failed heating element BUT... If you unplug one of the heating circuit plugs inside the seat, the seat will do exactly the same!
So, if the seat has been stripped to the extent of replacing the switch pack... It could very easily be a plug not in correctly sir...
More investigation needed Rolling Eyes
If it were me, i would throw it straight back at the garage that replaced the trim they broke and insist they resolve this too! Thumbs Up
Post #308666 28th Jan 2015 10:06am
Oh and by the way... If it is an element... Urmmmm sit down first!!!!
Its a new base or back section complete! Shocked So your talking 4 figures! Whistle Whistle Whistle
Post #308667 28th Jan 2015 10:07am
Squirrel
Thanks Craig! I thought it was a bit of a coincidence that the seat stopped working at exactly the time they replaced the switch pack, so I gave them the car back and asked them to sort it. They said they'd checked and everything was plugged in correctly and that the heating element must have failed. And then they gave me a quotation for fixing it. Shocked
That was why I gave it to someone else for a look. He says he "couldn't see" anything wrong and also suggested a heating element failure. He suggested that we find a donor seat from somewhere and test it with that, rather than going to all the expense of replacing the seat base only to discover the problem is being caused by something else, but I have no idea where to start looking - and to be honest, if the donor seat works then we may as well use that.
Is there anything I can check for myself without hauling the entire seat base out of the car?
I was just thinking to myself that if I fix the heated seat then I'll lose this urge to trade the car up for a newer one. I think it's only a very small chance, but all the same. Very Happy
Post #308678 28th Jan 2015 11:11am
You can change the base's over from side to side i.e. passengers to the drivers seat! That way if its the base at fault, the fault should move to the other seat Thumbs Up
Helps with the wear on the outer side too Whistle Thumbs Up
Post #308679 28th Jan 2015 11:22am
Squirrel
I never thought of that! Thanks Craig, I'll give that a go. If the worst comes to the worst, I can swap the two permanently - it doesn't bother me if my passenger has a cold bum. Rolling with laughter
Post #308696 28th Jan 2015 12:42pm
Ianmaney
United Kingdom 2011 Range Rover Vogue SE TDV8 Mariana Black
The same has happened to mine, I got a quote from LR of £900.00 for new leather as apparently, the heating element is bonded to the leather................It'll be summer soon......... Thumbs Up Semper in merda sumus, solum altum variat !!
Current: 2011 4.4 TDV8 Vogue SE
Last one: 2003 3.0 TD6 Vogue
Post #308722 28th Jan 2015 2:42pm
As i said above Ian, have the bases swapped from side to side Thumbs Up
Post #308727 28th Jan 2015 2:47pm
Ianmaney
I would Craig but SWMBO would suffer with cold posterior syndrome, and that's just not worth it....... Big Cry Semper in merda sumus, solum altum variat !!
Post #308730 28th Jan 2015 2:51pm
Sit her in the back Ian... Peace & quiet! Razz Whilst she feels important! Laughing
Mrs Bucket syndrome Whistle
Post #308736 28th Jan 2015 2:56pm
Ianmaney
I'll put it to her, so if you don't hear from me..................
Rolling with laughter Semper in merda sumus, solum altum variat !!
Post #308739 28th Jan 2015 3:00pm
Laughing Laughing Laughing Thumbs Up Bow down
Post #308879 29th Jan 2015 12:19am
Zambezi
United Kingdom 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
Has anyone tried / succeeded in using an aftermarket heated seat pad inserted under the knackered leather with the stitched in original heat element ?
http://www.ebay.co.uk/itm/2-Pairs-Carbon-F...564aeb3685
My driver's side is failed and I'm looking to repair it without having to replace the whole seat assembly.
Thanks.
David
Post #315793 2nd Mar 2015 10:55pm
