![]() | Home > Maintenance & Mods (L322) > Water in wheel well |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3950 ![]() ![]() ![]() |
Is suppose it had to happen but my car seems to leak into the area under the boot floor. I guess I could just sit in the back and persuade SWMBO to get the hosepipe out and see if I can see where it's coming in from and then look at ways to stop it. OR I could be pragmatic and just drill a couple of drain holes in the boot floor - has anyone tried this is there any downside. Geoff |
Yes, I've been having a look and although I did fit a tow bar recently the carpet on the left is wet (as you look into the boot) so as its higher up I suspect the seal. In the posts £94 is mentioned for a replacement I might try first with some non setting mastic. Maybe Sikaflex 512 or similar |
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1902 ![]() ![]() ![]() |
Geoff the replacement boot seals come with NON setting sealant inside them pal... So you remove your old one and CLEAN everything up then the new one seals as you fit it |
duckworthparts Site Sponsor Member Since: 30 Jun 2011 Location: Market Rasen, Lincolnshire Posts: 5217 ![]() ![]() |
£96! |
Thanks all,
![]() Now thats interesting as I have had the seal off to lower the head lining so I could fit the rear dash camera and wiring ....hmmm need to look closly at the seal in the corners more. If it dont work.......burn it! If the IId tool cant fix it.......burn the FF. If the FF cant be fixed......buy a Land Cruiser! If the LC cant be fixed..............................................BUY a horse !! |
Potentially your seal is now 11yrs old and removing/refitting it will have disturbed the already dried out sealant so, may well be your issue sir...
I think mine may have got disturbed when they fitted a new tailgate, or more likely the new tailgate can't bed in the existing seal which was bedded in by the previous tailgate - does that make sense? Geoff |
That'll be it then Geoff... Getting to bolts wiring etc it would have been removed & refitted for sure! |
So as it was a warranty repair maybe the garage should be fixing |
Thanks Craig, Just been out to check it has been |
Geoff, make sure you get it properly dried out too my friend... I guess that is where electrical issues may stem from 5 years down the road |
@ Craig , yes I'm thinking more towards the seal now after removing it, tow bar going to be fitted some time soon so will do the seal after that |
