![]() | Home > Technical (L322) > Can I trickle charge my battery in situ? |
JST Member Since: 12 Dec 2013 Location: Somerset Posts: 502 ![]() ![]() ![]() |
i have in the past yes. Cheers
paulmoran2 Member Since: 27 Nov 2013 Location: Leeds Posts: 1422 ![]() ![]() ![]() |
Yes...mines on the CTek right now . I give it a good charge every couple of weeks as I only do low miles.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8000 ![]() ![]() ![]() |
Same as Paul, I have the CTEK comfort connector on my battery and charge up every few weeks, as I only do about 10 mile a day and watch TV a bit at lunch times......
EmiratesA380 Member Since: 14 Jan 2015 Location: england Posts: 361 ![]() ![]() ![]() |
Hi mrblonde
mrblonde Member Since: 24 Jan 2012 Location: Cambs Posts: 766 ![]() ![]() ![]() |
Cheers all
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3986 ![]() ![]() ![]() |
Connect to whichever is most convenient for you. |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3817 ![]() ![]() |
or through the white trailer electric socket if you have one - saves opening the bonnet and plugs straight in if you wire a cable to the appropriate trailer plug to plug straight into the car socket - this is the quickest and safest way inho.
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 ![]() ![]() ![]() |
I have one and they work great - no need to lift the bonnet |
If this is any help to anyone.
wilwak Member Since: 02 Oct 2015 Location: Hampshire Posts: 27 ![]() ![]() ![]() |
Ive just taken delivery of my new L405! Love it.
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1428 ![]() ![]() ![]() |
I don't know about the 405, but when I had a battery failure on my 2004 322 4.4 (in a field by the Tweed on a Friday evening, sorted by Donald Lees Recovery of Galashiels who had the off road capacity to reach me) I needed to keep the battery alive over the weekend and had just a Triumph motorcycle branded trickle charger with a power socket adaptor to hand. I plugged that into the cigarette lighter socket and the charger showed it was working. I then just shut the (front) door on the charger cable and locked the car. There seemed no damage to cable or door seal (or the car's electrics) and the car started on the Monday and I got a new battery.
Thanks CS. The pwer socket option is a good idea.
Nothing in the manual about battery location....
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2951 ![]() ![]() ![]() |
I have an Optimate charger and I bought an extended lead to connect to the battery. I also use the trailer socket using another Optimate cable and a plug I bought from a caravan shop.
