Home > Technical (L322) > 11 Plate TDv8 4.4 VSE Noobie Questions
jeffw
United Kingdom 2011 Range Rover Vogue SE TDV8 Santorini Black
Picked up my new FFRR yesterday Smile
I've noticed a number of things which surprise me having come from a 09 plate Jag XF 3.0Tdi Premium Luxury and just wanted to check that it was the car and not me being silly.
1. Reversing Camera. On the Jag the reversing camera was central and the yellow lines lined up with the direction of the car (one set show directly back and another set show where you will turn too with the steering lock that is currently on). The RR seems to have the camera offset to the right of the vehicle and the yellow lines are at an angle to the direction of travel (approx 10-15 deg). I appreciate there is no lines for the steering input but the offset lines seems odd.
2. Reversing Sensors. On the Jag the audio system would reduce the volume in reverse so that you could hear the sensor beeps....the distance would also show up on the camera in orange or red depending on how close you where. The RR sensors work but I can't hear them unless I turn the radio down and there is no colour indication in the camera display.
3. The Jag would dip the nearside mirror in reverse, the RR doesn't appear to do this.
any thoughts? 2011 4.4 TDv8 Vogue SE
Zeus Challenger Evo II
Post #309048 29th Jan 2015 4:43pm
Andy B
Hi Jeff,
I hope you are enjoying the new Full Fat! Regarding point 3, there should be a setting on the main TFT menu to dip the mirrors on reverse.
Cheers,
Andy SDV8 AB MY 2019
SDV8 VSE MY 2015 - Gone
5.0 S/C AB MY 2010 - Gone
4.2 S/C VSE MY 2006 - Gone
Post #309057 29th Jan 2015 5:22pm
discowill
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
I have a 2011 FFRR AB Black and it has the lines that follow the steering and also a line at the bottom that goes from yellow to orange to red with the 4 sensors showing on it as blocks so you can tell which one is giving out the beep, don't know about the audio bit as I always turn the stereo down, I will give it a go and see, as said before the mirror dip function is controlled from the steering wheel button going into the settings menu in between the speedo and rev counter, hope this helps.
Post #309070 29th Jan 2015 6:28pm
jeffw
Found the dipping mirror Smile
The camera thing is a little odd... 2011 4.4 TDv8 Vogue SE
Post #309071 29th Jan 2015 6:38pm
CEEGEE
I have a MY '10 VSE and on points 1 and 2 its the same as yours - antiquated isn't it Whistle
But there are lots of pluses that make up for some of the ageing technology Thumbs Up
Post #309072 29th Jan 2015 6:55pm
Philip
2019 Range Rover Autobiography SDV8 Aintree Green
Reversing camera lines are fixed unless you have Vision Assist.
Post #309073 29th Jan 2015 7:01pm
jeffw
Ahhhhh....OK. Thanks.
Am I meant to have a Venture Cam ? 2011 4.4 TDv8 Vogue SE
Post #309109 29th Jan 2015 8:54pm
CEEGEE
No.
Post #309110 29th Jan 2015 8:55pm
jeffw
Sad
Good thing I checked before I bought one off Ebay ....hang on...its arrived Sad Anyone need a Venture Cam and mount? 2011 4.4 TDv8 Vogue SE
Post #309116 29th Jan 2015 9:37pm
CEEGEE
Oooops - other than mounting it in a horse box to keep an eye on things I could never really understand when and why you would ever use one - sounds like a thread starter Thumbs Up
Post #309129 29th Jan 2015 10:09pm
jeffw
I have a covered trailer for the race car and thought it would be a good idea... 2011 4.4 TDv8 Vogue SE
Post #309131 29th Jan 2015 10:12pm
CEEGEE
Valid - add it to the list on the thread I just started - good luck with the new FF Thumbs Up
Post #309134 29th Jan 2015 10:15pm
