![]() | Home > Technical (L322) > Alternator charging rate? |
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8825
Well it takes about 40seconds to replace the power taken out of the battery from a normal start....
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8788
Was perfectly perky after a bit of a run yesterday but didn't show a full charge on the ctek initially, but to be honest I didn't really wait too long as it was snowing.....
Yep, you will look a bit silly trailing an extension lead down the road......
| JAYBOY Member Since: 17 Oct 2012 Location: South Wales Posts: 2204
I was told that 13 miles will charge it back up although I'm not sure if thats a nearly flat battery. |
| JST Member Since: 12 Dec 2013 Location: Somerset Posts: 503
from flat and needing a booster to start, mine restarts after an 8 mile drive. Cheers
| comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1764
JST - from flat and needing booster cables to start I suspect the 8 mile drive will give it enough to be able to start the car but will not be a full charge.
good point Ash, i misread the post, thought it was how long from a flat start to get it to restart off own battery. Cheers
I would suspect that to put a full charge into the battery from completely flat would take several hours of running, but I suppose it's an open question as it depends on how much charge is actually left in the battery.
| All times are GMT |
