![]() | Home > Maintenance & Mods (L322) > does this price sound right ? |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8718 ![]() ![]() ![]() |
You can get 20ltrs of the oil for about £120, original filter and gasket less than £50 and it would take you less than 2 hours lying on your back...
markcaughey Member Since: 03 Nov 2014 Location: Glasgow Posts: 316 ![]() ![]() ![]() |
I was considering doing it myself but the only thing that put me of was how do you measure the oil temperature when topping off the fluid to the correct level ? As I said in a previous post I have a infra red laser thermometer but that would only measure the temp of the plastic pan and not the actual oil.
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1847 ![]() ![]() |
The sleeve is a very cheap, serviceable part, and if they are dropping the sump anyway, it only takes an extra 60 seconds to replace |
Haylands . The price I got from dan was £23 per litre ?? Range Rover Vogue 2006 4.4 AJV8 | Buckingham Blue | Parchment Leather | Supercharged Grill+Side Vents | CA02 HEY ( NOT 02 PLATE ) |
It's different oil between the 5speed and 6 speed gearboxes. £23 a litre is still very expensive though |
What should I expect to be paying for the oil ? And where from ? Range Rover Vogue 2006 4.4 AJV8 | Buckingham Blue | Parchment Leather | Supercharged Grill+Side Vents | CA02 HEY ( NOT 02 PLATE ) |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6819 ![]() ![]() ![]() |
They quoted me £275+vat last week. Got - 2017 SDV8 Autobiography in Loire Blue
Oil is £12 a litre |
yeah thats what they quoted me before i mentioned the sleeve needed replaced wow that a fair bit cheaper mikey wheres that from ? Range Rover Vogue 2006 4.4 AJV8 | Buckingham Blue | Parchment Leather | Supercharged Grill+Side Vents | CA02 HEY ( NOT 02 PLATE ) |
anyone ever used this stuff ?
That's the oil I use when doing gearbox flushing ![]() |
