|  | Home > Technical (L322) > Exhuast Gas Recycling Valve TDV8 |
| kingpleb Member Since: 07 Jun 2011 Location: Maybe here. Maybe there, I get everywhere! Posts: 8455      | It will generally make the engine better as you are not re-using dead air as it were.
|  18th Jul 2012 1:10pm |
| DMRR Member Since: 14 Apr 2010 Location: Northamptonshire Posts: 2027      | I thought the TDV8 had 'self cleaning' EGR valves   | ||
|  18th Jul 2012 1:14pm |
| kingpleb Member Since: 07 Jun 2011 Location: Maybe here. Maybe there, I get everywhere! Posts: 8455      | Is that the fairies that go in and clean them  | ||
|  18th Jul 2012 1:31pm |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35883    | they can probably be cleaned..joe90 cleaned his td6 valve so its possible.. ... - .- -.
|  18th Jul 2012 1:52pm |
| Andy3681 Member Since: 13 Jan 2012 Location: Newcastle under lyme/ Le Dorat Haute Vienne Posts: 912      | TD6 one no problem to clean out, they can get choked with carbon. Did mine before I decided to remove it. I have read reports of the ones on the Sport and Disco needing cleaning so should be a straightforward job but not done it so can't comment on whats involved. However it is probably easier to clean if you take them completley off. Mine was a blue one!  | ||
|  18th Jul 2012 2:34pm |
| verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952      |
 TDV8, TDV6, SDV6 and TD4 (Puma) valves are all self cleaning, but still do get blocked... l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l Current RANGE ROVER Vogue 4.4L SDV8 - 2013 - Indus Silver, on Almond. RANGE ROVER Vogue 4.4L V8 - 2002 - ex-2003 G4 Challenge Event Vehicle, Stage 3: Australia RANGE ROVER HSE 4.4L V8 - 2004 - one-of-one Overfinch RANGE ROVER P38a 4.0L V8 - 1999 - ex-2000 TReK Event Vehicle: South Africa Previous: RANGE ROVER Vogue 4.4L TDV8 - 2012 - RANGE ROVER 3.6L TDV8 x3 - RANGE ROVER Td6 x1 - RANGE ROVER Classic 3.5L V8 x1 | ||
|  18th Jul 2012 2:36pm |
| Stingclive33 Member Since: 07 Jan 2012 Location: Rye Posts: 28      | on the cleaning angle, apart from actuall carbon build, up are EGRV'S liable to fail in any other way, dodgy electronics for example? | ||
|  19th Jul 2012 8:08am |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35883    | its the mechanics that normally get clogged up..electrical bit should be ok.. ... - .- -.
|  19th Jul 2012 8:16am |
| Stingclive33 Member Since: 07 Jan 2012 Location: Rye Posts: 28      | Thanks Stan and Ivor, I always impressed by the level of knowledge and support on this great forum | ||
|  20th Jul 2012 6:27am |
| Bellini Member Since: 11 Jan 2012 Location: Berkshire Posts: 2261      | EGR blanking kits are very common Tdi and Td5 engines, although I'm not sure how the more complex engine management and diagnostic systems would cope with them. Si. <This is my name.
|  20th Jul 2012 6:59am |
| Gazellio @ Prestige Cars Member Since: 22 Jan 2010 Location: Chilterns, UK Posts: 11309      | WYNNS EGR DIESEL CLEANER...
|  30th Jan 2015 6:51pm |
| paulmoran2 Member Since: 27 Nov 2013 Location: Leeds Posts: 1422      | Holy thread resurrection Batman   | ||
|  30th Jan 2015 7:47pm |
| Gazellio @ Prestige Cars Member Since: 22 Jan 2010 Location: Chilterns, UK Posts: 11309      | Does anybody know the book number of LR labour hours charged for swapping out both EGR valves? | ||
|  5th Feb 2015 7:51pm |
| Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1885    | Book time is 2 hours for both valves...
|  5th Feb 2015 8:31pm |
| Posting Rules
