![]() | Home > General > Whoi Says the 5.0 isn't economical |
DrF Member Since: 30 Jun 2014 Location: South East Posts: 1513 ![]() ![]() ![]() |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16398 ![]() ![]() ![]() |
Down a long hill |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1763 ![]() ![]() ![]() |
Nah - I can see Cruise Control is active and so is follow mode... I bet the gap is set to the shortest and you are slip streaming a lorry by about 4 feet... Ash
also just noticed the yellow marker on your speedo. Whats that? is it a speed limiter (or bong at least) Ash
Limiter bonger yes... |
markcaughey Member Since: 03 Nov 2014 Location: Glasgow Posts: 316 ![]() ![]() ![]() |
I can believe that |
A1GSS Member Since: 24 Dec 2010 Location: Saffron Walden, Essex Posts: 1973 ![]() ![]() |
Tempting.... |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3807 ![]() ![]() |
Yes its possible if you drive like a fart |
I certainly don't see that kind of average from my TDV8 |
JAYBOY Member Since: 17 Oct 2012 Location: South Wales Posts: 2204 ![]() ![]() ![]() |
21Mpg on my 4.4TDV8 |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6829 ![]() ![]() ![]() |
If you get 21 from your 4.4, just imagine how little you'd get with the 5.0 |
Alan i recon about 12 |
JackRegan Member Since: 20 Oct 2012 Location: Wirral Posts: 258 ![]() ![]() |
Just looked at mine, since I've owned it I've done just shy of 9k at an average of 20.7mpg according to the OBC, so likely to be slightly lower in real life.
Surely you tdv8 guys get more than that on a good run ??? Range Rover Vogue 2006 4.4 AJV8 | Buckingham Blue | Parchment Leather | Supercharged Grill+Side Vents | CA02 HEY ( NOT 02 PLATE ) |
