Home > Maintenance & Mods (L322) > Bosch s5 silver 110ah 020
Page 4 of 4 <1234
I got my first one in without too much of a problem - just make sure you open the bonnet to full height
However, the warranty replacement just would not go in.
When I measured them, the new one was about 5mm longer - so I had to cut the tab on the base off - then it went in no problem Thumbs Up
Post #309126 29th Jan 2015 10:06pm
In case you don't know - you can open your bonnet wider - and it makes fitting the battery much easier.
You need to disconnect the lower end of the gas struts as they limit the opening
There is a locking clip on each hinge to hold the bonnet nearer to vertical
Just be careful with the clips from the struts - I lost one taking it off
Post #309130 29th Jan 2015 10:09pm
^ it's in the WIKI.....
http://www.fullfatrr.com/forum/topic16561.html Previously..
Post #309158 29th Jan 2015 11:35pm
noworries4x4
I have just fitted this bigger battery to my 07 tdv8, mine had a tiddly 013 in it no wonder it struggled sometimes. The battery fitted easily but the positive connector would not fit in any way shape or form. Mine does not have the jump peg on the bulkhead or the explosive disconnect, but mine does have the box with the 400amp fuse in it. I ended up putting a short jump lead in the system and the fuse is now zippy tied to the battery handles. Not the greatest solution and will look to do better in the future. I tried to heat up the clamp/bracket but it is cast brass and just broke. If everything is under control you are not going fast enough.
MY 16 Discovery 4 Commercial Workshop and Escort Vehicle
MY 12 Full Fat TDV8
1952 Series 1 80" 3ltr 6cyl
Post #309425 31st Jan 2015 10:59am
noworries4x4
I know it does not look the best but it works and as other posters have said everything seams to be working a bit better/faster probably complete Censored but makes me feel warm and fuzzy for 10mins
MY 12 Full Fat TDV8
Post #309508 31st Jan 2015 8:53pm
Page 4 of 4 <1234
