Home > Maintenance & Mods (L322) > Sound of water when cornering
Ozzy Rangie
Australia 2002 Range Rover Vogue 4.4 V8 Java Black
L322 Rangie 2002
I am getting a swishing noise of water when cornering at low speed, sounds like it is coming from behind the Dash.
Had the same noise some months ago but during the summer the noise disappeared, but there was a heavy down pour a couple of days ago and the noise is back.
Has anyone else had the same problem or know what it might be?
Any help would be much appreciated.
Thanks
Post #309560 1st Feb 2015 7:48am
hoppy_70
England 2018 Range Rover Autobiography 2.0 PHEV Loire Blue
Check the venty bit below the windscreen. Water from the screen should drain through holes that can get blocked with leaves. My Previous RR's!
2018 P400e Autobiography
2008 TDV8 Vogue
2006 TD6 Vogue
2007 TDV8 Vogue
2007 RRS (I know, it doesn't count!)
2005 4.4 Vogue on LPG
2005 TD6 Vogue
2003 4.4 Vogue
2001 4.6 HSE
2000 2.5 DHSE
1999 4.6 HSE
1997 4.6 HSE on LPG
1995 2.5 DSE
1989 3.9 EFI classic
1988 3.5 EFI classic
Post #309565 1st Feb 2015 8:18am
Ozzy Rangie
Hi
yes the drain pipes on left and right hand side are both clear, the centre drain by wiper spindle does not have a tube/pipe attached it drains straight onto the top of the removable air intake box for the heater.
Post #309567 1st Feb 2015 8:45am
mzplcg
Check the sunroof drains. Quite common with Land Rovers.
Post #309569 1st Feb 2015 9:11am
Ozzy Rangie
Hi
Just been to check and water is running through ok no blockages.
The noise is like water runing from one side to the other in a partially filled tube.
Post #309573 1st Feb 2015 9:24am
Could it be condensate in the tray below the evaporator.
Shouldn't be any water in it but there would be if the drains are blocked. Thumbs Up
Post #309724 1st Feb 2015 4:49pm
jakebullet64
United Kingdom 2003 Range Rover Vogue 4.4 V8 Santorini Black
Like this?
http://www.fullfatrr.com/forum/topic2909.h...tion+water
Jake 2003 Range Rover Vogue 4.4 on Gas
1961 88" 2.25 diesel - George
Gone - 1997 3.9 V8i Discovery - Burt
Post #309814 1st Feb 2015 9:35pm
Silversurfer13
United Kingdom 2008 Range Rover Autobiography TDV8 Java Black
Fuel tank. I sometimes get caught out before realising Confused
Post #309826 1st Feb 2015 11:00pm
Ozzy Rangie
not fuel tank, tank is at 3/4
Post #309871 2nd Feb 2015 5:57am
nobbyclark
My old car (Cayenne) had drainage tubes that ran along under both doors on each side. Were supposed to drain out behind the wheel arch cover at the front but this often got blocked by salt/grit/mud etc. Not sure if the RR has a similar design?
Post #309899 2nd Feb 2015 10:28am
jakebullet64
what about this?
http://www.fullfatrr.com/forum/topic2909.html 2003 Range Rover Vogue 4.4 on Gas
Post #309928 2nd Feb 2015 12:10pm
Ozzy Rangie
Thanks for that, reckon its the same problem.
Just got to figure out where to drill the holes to let the water out!
Post #309946 2nd Feb 2015 12:43pm
