Home > Maintenance & Mods (L322) > Transfer Box Oil Change
pld118
Hi,
Going to change the oil in the Transfer Box. For the 4.2SC, the Workshop Manual says 1.5L required and that it should be:
Transfer Case Fluid Shell TF0753.
Have only seen this advertised online with Rimmer Bros. Is it not easy to come by and likely only available either main dealer purchase or online with Rimmer Bros?
Thanks.
Post #309598 1st Feb 2015 9:30am
Ducky Dan Whistle Thumbs Up
Post #309622 1st Feb 2015 10:39am
pld118
Laughing Laughing
Knew you'd say that... Sunday morning impatience... Was hoping to nip out, buy it and get the job done!
Post #309624 1st Feb 2015 10:41am
I have some on the shelf if ya wanna just "pop down" Ryan... Whistle
Post #309629 1st Feb 2015 10:44am
How are main dealer prices too high ... ====================================
Post #309630 1st Feb 2015 10:47am
pld118
Not bothered about the price Joker (think Rimmer Bros quote about £24 incl VAT/ 1 Litre so fair enough). I struggled to find other seller's when googling this oil. Read on other forums that this particular oil isn't that easy to come by and that you can pretty much only buy it at main dealers. No main dealer that near to us.
Just wanted to do the job today and hoped it was maybe on mainstream sale so I could pop out, buy some and get on with it. That rules out raiding your shelf Craig/ thanks though Laughing
You need new washer seals for the drain and filler plugs anyway so perhaps a bit of patience will be a virtue! Thumbs Up
Post #309641 1st Feb 2015 12:13pm
pld118
Ordered by means of a 2 minute phone call to Dan at Duckworths LR this morning.
Supply your chassis number, know you're getting the correct oil for your car and that it will be promptly delivered. 2 litres ordered, new drain and fill plugs (just in case) and 2 new washer seals.
Great service off Dan/ Duckworths as ever Thumbs Up
Post #309915 2nd Feb 2015 10:19am
markcaughey
Scotland 2006 Range Rover Vogue 4.4 V8 Buckingham Blue
Well worth doing. Very easy to do and very cheap when DIY Thumbs Up Range Rover Vogue 2006 4.4 AJV8 | Buckingham Blue | Parchment Leather | Supercharged Grill+Side Vents | CA02 HEY ( NOT 02 PLATE )
Post #309918 2nd Feb 2015 10:30am
pld118
Changed this oil myself the other week by means of following the LR workshop manual and by using LR approved materials bought from Duckworths LR, including new drain and filler plugs and the copper seals (noted the date and vehicle mileage on the Duckworths LR invoice for the oil).
1.3L drained out. The LR workshop manual says 1.5L is the capacity.
The drained transfer box oil was a very dirty, dark coloured oil as opposed to the lighter golden brown oil that I put back in. Again, not a drop spilled during the process and no subsequent leakage.
Access to do this straightforward and worthwhile job gained from underneath the passenger side of the car.
Post #313441 18th Feb 2015 12:10pm
Is a "special oil" Ryan that's why it's difficult to get hold of and tends to only be available from MD. have had mine done a couple of times as a result of having the transfer case split and re sealed to cure the leak which was caused by the high low switch. There is nothing that can't be fixed with a hammer😜😜
M3 3.2 EVO Convertible Techno Violet
Post #313586 19th Feb 2015 7:38am
Garyfax
England 2009 Range Rover Vogue SE TDV8 Santorini Black
Advanced factors sell the transfer box oil for £8.07 per litre.
Post #357738 19th Nov 2015 4:52pm
