![]() | Home > Maintenance & Mods (L322) > Wheel alignment post strut change? |
Best to change both at the same time, due to the shock absorbers within.
If the bag has a hole you won't need to deflate it sir |
Actually you can deflate individual corners using the test valve function - but it is better to do a "deflate all" as the suspension has no air afterwards and cannot shift anymore until you run the engine so that the compressor switches on. Depending on how you have the RR jacked up to do the work, you may not want to have the corners on the ground to self level while you are doing work under the car |
v8rich Member Since: 28 Dec 2013 Location: Healing, Lincolnshire Posts: 67 ![]() ![]() ![]() |
Thanks, looks like I'll have to dig deep then this month and get two front struts! |
PM sent sir |
