Home > Maintenance & Mods (L322) > Engine Check Light
mick-ne
England 2004 Range Rover Vogue 4.4 V8 Java Black
Engine Check Light
Hi All, I have had the oil service light showing for a few weeks and today the Engine check light came on. Can these be related ? Are our vehicles sophisticated enough to put on a light if I have ignored the oil service or is this likely to need a plug in. Thanks Mick.
Post #309754 1st Feb 2015 6:14pm
When did you last check the oil? Shocked .
Post #309777 1st Feb 2015 7:27pm
mick-ne
Don't worry that was first on the list, any messages connected to oil ring a big bell inside my head. I have a oil and filter change planned but the weather has been freezing,lol.
Post #309804 1st Feb 2015 8:53pm
AFAIK the two are not related, engine light comes on when there is an error with something that effects emissions.... Pete
Post #309817 1st Feb 2015 10:38pm
mick-ne
Emissions well my car has lpg do you think prolonged use could have upset a sensor.
Post #309827 1st Feb 2015 11:03pm
Shouldn't do if it's set up properly, emissions would be lower on LPG anyway...
You will need to get the fault code read, should be able to do it with any OBD2 reader, although my cheap one will read faults it won't clear them so bought an IID tool and it paid for itself in a very short period of time.... Pete
Post #309836 1st Feb 2015 11:20pm
mick-ne
MULTIPLE FUEL TRIM 1.LIMIT REACHED
That's the code if anyone has any ideas it has been cleared today and so far has not came back.
Thanks Mick
Post #310074 2nd Feb 2015 10:04pm
Andy_J
Scotland 2007 Range Rover Vogue SE TDV8 Java Black
It is either running lean or rich and has reached the point where the ECU can't trim the fuel delivery back to 'normal'. Can you read the fuel trim values with you FCR? 56 TDV8 Vogue SE
9 Freelanders, 2x 2002 TD4ES, 2001 TD4, 2002 1.8GS, 2000 XEDI, 2x 2000 1.8ES, 2004 1.8 & 2000 1.8 GS (rolled)
91 Lotus Carlton (sold)
90 Lotus Elan (BRG)
Post #310076 2nd Feb 2015 10:14pm
mick-ne
Well had the live data read today and everything looks to be within correct spec light still off so its a waiting game I think,
Post #310323 3rd Feb 2015 8:43pm
