Home > In Car Electronics (L322) > Ipod adapter, how to get behind most cd player?
clemenz
Austria 2006 Range Rover Vogue Td6 Zermatt Silver
Hello folks,
i'm planning to buy this adapter for ipod http://trioma.ru/products/usb/skif-volvo.shtml as
what i have searched is one of a few possibilities to get full ipod integration in an MY06.
I had contact with the supplier and with shipping to austria this thing will cost euro 160,- incl usb adapter.
sounds good, so it will provide usb and ipod.
the idea behind this box is that its in the most chain before the cd player and if a usb is attached it will disable the cd unit
und emulates the cd changer. sounds quite interesting! price is without competition (if i get the parcel Very Happy).
the other thing is the installation. as we have just a few car hifi shops here i will do it on my own.
so can someone tell me if its hard to install this box behind the cd player?
where to get ignition plus and minus from?
THANKS
Post #309987 2nd Feb 2015 4:18pm
use the cd players positive and negative feed..
how to remove cd player here, http://www.fullfatrr.com/forum/topic14875....+cd+player ... - .- -.
Post #309991 2nd Feb 2015 4:35pm
clemenz
thanks!
Post #309995 2nd Feb 2015 4:58pm
miggit
If you need a switched Accessory power feed, you can plug in to fuse 7 in the glovebox, but make sure that you have a fuse in the unit or fit an inline fuse. If memory serves me correct it's the top hole that's the switched live, so that should be the one that you want, but if it doesn't work plug it in the bottom hole ! there's a 50% chance that I'm wrong Wink
Oh and test it all before you put it all back together again Wink otherwise you might find yourself taking the Censored glovebox out again Laughing Yesterday I couldn't spell Engineer... Today I are one!
Post #310411 4th Feb 2015 12:47am
Scottyav
United Kingdom 2007 Range Rover Autobiography TDV8 Zambezi Silver
Sounds good if they had English site about £130 would that be to uk as well?
Post #310415 4th Feb 2015 1:25am
clemenz
you have to ask the price per icq Very Happy or skpe.
i decided to start with the project when its warmer outside,
now i'm doing the flip key upgrade...
Post #310417 4th Feb 2015 1:31am
Scottyav
I can't speak Russian though Big Cry how much from Austria Whistle
Post #310419 4th Feb 2015 1:48am
clemenz
they speak english Thumbs Up
Post #310457 4th Feb 2015 10:34am
mpirie
If this thing works, I think they'd see a string of orders from the forum members!
Mike
Post #310459 4th Feb 2015 10:52am
Weegie
Google translate for the opening description. Hope it helps. System looks quite good for the money
Ø Car interface MOST:
s Volvo XC90 / S40 / V50 (2002-2012) and the Volvo XC70 / S80 (2007-2011)
s Land Rover Freelander 2 (2006-2012) and the Range Rover Vogue (2005-2009)
Ø plays MP3 files from USB-flash drives;
Ø manages folders (up to 15) and files (up to 99 in each folder) using the buttons on the head unit and steering wheel.
Ø support joint work with the standard CD-drive;
Ø allows arbitrary folder and file names, as well as the presence of non-music files and folders;
Ø displays the number of folders and files, as well as their names (if supported by the tape recorder);
Ø translates Russian characters to Latin, Russian characters display (if supported cassette);
Ø remembers the exact playback position on a flash drive during system shutdown or when removing the stick;
Ø additional port to connect AUX, iPod / iPhone / iPad, module Bluetooth (through the appropriate accessory).
Ø as well as the ability to customize, quick start mode, Random, a simple algorithm update John
GAP iiD BT-Sold
Post #310483 4th Feb 2015 1:07pm
RR2008HSE
For those of us who don't speak/read Russian,
Cost?
Is this plug n play or a big job to install?
Thx
Post #310738 5th Feb 2015 2:59am
clemenz
english pdf here:
http://www.12volt-shop.com/files/File/ERTA...vo_ENG.pdf
Post #310901 5th Feb 2015 5:26pm
RR2008HSE
Thanks, Clemenz. That's an interesting read.
Still curious about ease of installation and price.
Post #311447 7th Feb 2015 11:51pm
clemenz
i will order it soon it gets warmer outside cause we have
only a carport at home. when i install it i will post pictures!
Post #311588 8th Feb 2015 7:30pm
RR2008HSE
Thanks.
I'll look forward to your report.
Post #311650 8th Feb 2015 10:58pm
