Home > Technical (L322) > Air Suspension Inactive - need to get home
mrblonde
United Kingdom 2003 Range Rover Vogue Td6 Adriatic Blue
After 5 years or pretty much stress free driving, today I pulled into work at 6am and the 'air susp inactive' error came up. The light on the button that prevents it being used was continually on, and it wouldn't lower to access height (how i usually leave it when I park up - heard it helps it 'go to sleep completely')
Can I drive the 6 miles home after work with it still on? Didnt notice anything different today driving in through the sprinkling of snow, it felt fine. And not sure how long the light on the height control button/roller switch had been on?
What should I check first?
Post #310130 3rd Feb 2015 7:46am
ebajema
If the car is at normal operating height and it seems to behave fine I would drive it home and look at fixing it there. MY 2010 5.0 SC Galway green and sand interior!!
Post #310132 3rd Feb 2015 8:07am
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
+1 try a battery reset .
Funny things these range rovers
Post #310137 3rd Feb 2015 9:03am
Switch the engine on, turn full lock to left and right, turn engine off, turn engine on and you might be lucky.
Could just have been a low voltage blip.
If not, as above, drive the car home as it is. Thumbs Up
Post #310138 3rd Feb 2015 9:04am
mrblonde
Cheers guys will try the left/right reset first, and hopefully get the old girl home.
I'll charge the battery this afternoon as she sits for 7-20 days at a time without use. What would be next to check once the battery's full charged?
Post #310143 3rd Feb 2015 9:13am
n1cktdv8
I had this yesterday....
Shocked
Was ok, got jet washed, went on 'one' !
Had mine plugged into the computer last night, checked the whole system, reset the codes. Now all good....
The mystery world of LR ownership ! Is this where I put the car details and a bit about myself ?........
Post #310153 3rd Feb 2015 10:04am
Swiftman
Scotland 2006 Range Rover Vogue SE Td6 Zermatt Silver
suspension
had this happen twice in 2years . disconnect battery leave 15 mins reconnect start engine then follow other advice with steering wheel . it cured mine
Post #310180 3rd Feb 2015 11:38am
n1cktdv8
Well mine is holding up....fingers crossed ! Is this where I put the car details and a bit about myself ?........
Post #310227 3rd Feb 2015 2:30pm
Andy
I drove mine for 3 months with this fault. Didn't cause any problems
Post #310960 5th Feb 2015 7:57pm
