Home > Technical (L322) > Gear shift lever replacement
funnyguy1
United States
Has anyone ever changed the gear shift on a 2010-2012 L322? There is a video on an older L322 but mine has the stainless plate that surrounds the shift boot and I don't think it snaps out from it. Thanks in advance!
Post #310330 3rd Feb 2015 9:04pm
verydisco
Hi
A picture would help, but most likely yours is identical to older model (i.e. an actual gear lever, not the rotary knob)
To get the metal piece off, take the gear-lever off (simply pull it up) then turn it upside down, using a plastic trim tool (or a screwdriver with thick tape on it), lever the thin and narrower part of the metal trim, then lift it all up.
It is tight but you will get it. l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #310339 3rd Feb 2015 9:30pm
funnyguy1
United States
Update: So I have ordered a new gear shift lever. The leather part pops out of the stainless surround with 4 snaps and then the lever while new neutral pulls straight up and the other goes right back in. I changed one on my SPORT and it took about 3 minutes or less. The dealer has 2 hours to replace if they do it. Is that normal for dealers to charge that much for such an easy replace?
Post #310986 5th Feb 2015 8:56pm
