![]() | Home > Technical (L322) > headlight beam |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35771 ![]() ![]() |
a question to those that might know, if i adjust my headlight beams so they both point right in front of me and to the middle of the left hand side road [like bmw flat beams] , will i need to use the tourist lever if i drive in europe.. ... - .- -.
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3268 ![]() ![]() ![]() |
Won't you still have the "pitch up" on the left side of the spread which would mean that even if you move everything to the right you would still have the likelihood of dazzling oncoming traffic.
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2283 ![]() ![]() ![]() |
What tourist lever is that Stan ? |
@john, agreed re using the tourist lever but my thoughts are to pull the nearside light to the right and the offside light to the left so they both project straight in front, unless the headlight glass it self stops this kind of beam pattern..
Don't know whether the glass would affect it. As there is quite a bit involved with the headlights eg. level adjustment, I think you might run into complications.
my beams have a kinda ^ shape and i have adaptive headlights so hence the initial question, just curious |
I go over to France a lot and have just used sticky tape mmm who is the numpty of the week then - didn't know they existed thanks Stan |
have you AFS headlights Sandy? ... - .- -.
I think so Stan they go through the dance routine on switch on |
Its a July 2007 4.2 s/c |
ah , then putting tape on the lens wont work cos the headlights turn when you turn |
