![]() | Home > Maintenance & Mods (L322) > Reverse lamp upgrade bulbs? |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
So next time I'm looking to do something like this it's Stans' led emporium |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35766 ![]() ![]() |
just a point, what if you need to separate the two again... ... - .- -.
Got a feeling that would be a tricky one, Epoxy is chemical resistant, but on the flip side, why would you want to split them again? all the led's are rated at 5000 + hours, that's just over 208 days continuous reversing |
Just done a few sums, I use the FFRR for siting mobile toilet trailers, and I recon that on a really busy day the most I'd be going the wrong way is 2 hours. Normally in a days use 2 minutes would cover total reversing. But going to the working calculation, 2 hours going backwards is 6.8 years over 5000 hours, there is no way the car will be working that long, a Landcruiser only lasts 3 years and then it's scrap |
crikey you must be bored |
Just be sound in the knowledge that we have done a better job at a sealed for life unit than JLR |
J evro Member Since: 31 Aug 2014 Location: Kent Posts: 541 ![]() ![]() ![]() |
Ok, so who is selling these units already done and ready to plug and play |
Steverr Member Since: 27 Oct 2013 Location: Bristol Posts: 191 ![]() ![]() ![]() |
Unnecessary quote removed
this is what you normally get when you buy the cob/smd panels Steve..self explanatory from the pic,
Steverr, just make sure that you get the ones with a BA9S adapter, and file one of the pins down, then it will plug in to the original bulb holder. As I put 2 panels in each light I cut the ends off 2 adapters and soldered them together so that I could feed both panels from each bulb holder, that way I could go back to original if wanted. I will admit to having to hold the BA9S bayonet in the holder and wrapping it with tape to keep it straight, as it tends to angle over because of only having 1 pin. But this is a good idea tape all the install wires from the holder to beyond the black plugs, to ensure that it doesn't come apart in transit |
Thank you very much. Just the info I was after.. Ordered the led's and are on there way |
Oh one last thing, before I forget, be careful when you put the lights in the boiling water. When I did mine , dropped them in the sink and emptied the kettle on them, and left them for a few minutes, that was OK. But, when I picked the first one up, for it's appointment with the surgeons knife, it dumped and load of very hot water on me, |
