![]() | Home > Technical (L322) > reduced engine performance |
| dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1419
got this ping up yesterday evening with a flashing CEL for a few seconds , car certainly was reduced in performance , couldn't pull the skin off a rice pudding.
| axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964
Thanks for posting that TSB , for a while now I have wondering when they rectified this and although not so good for you I find my vin No is comfortably after |
| crispy2 Member Since: 18 Aug 2013 Location: Mandurah Posts: 102
Hi folks, I'm trying to find out what the wiring configuration would be on the plug if my supercharger aux pump was still wired wrong.
| SKOT Member Since: 24 Oct 2012 Location: Milton Keynes Posts: 792
My SC fell in to the bracket of those with the aux coolant pump wired the wrong way around.
Mine had insulation tape......it was very obvious! 2006 4.2 SC 2019 Renault Zoe Dynamique Nav
Ok, thanks SKOT. I have the replacement pump coming to me and due Tuesday so I will install at next opportunity and swap the wiring around. It was not that dear so not worth not doing asif the REP were to occur how popular would I be if I said I wanted to save two hundred bucks! It is going to work hard towing the 2.5 tonne van and it can get quite warm here.
| scotbruce Member Since: 06 Dec 2014 Location: Aberdeen Posts: 39
Just had restricted performance come on at the Forth Road Bridge on the way down to Edinburgh and just managed to limp into Edinburgh city centre.
Car picked up yesterday, turbo hose replaced and returned, washed, today, without charge. Good stuff |
Ok Scotbruce, I see you have a TDV8. The REP warning within this thread above is unique to the S/C engine (the Supercharger coolant pump running in reverse) but clearly it can happen with a TDV8 as well.
Good morning, I did the changeout of the S/C coolant pump today. it was a |
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8825
Top job, glad it's sorted, that's what makes us love them, they need constant attention.... Pete
| gpzjamie Member Since: 11 Aug 2013 Location: newcastle upon tyne Posts: 14
Hi Guys, i realise that this is an old post, but, i have just had to replace my pump due to Land Rovers error, i lost power went onto reduced performance mode , so had it checked out, my Range is 2006 offs, how many times have land rover had the oppertunity to repair this in the cars life ?? it should have been a recall, or at least a service bulletin for the 4.2 supercharged. well, thats me 300 quid out of pocket........ jamie |
| jeep948 Member Since: 12 Aug 2013 Location: Scottish Borders Posts: 5
I have the same issue and my new pump arrived today, Sunday is the day for fitting. Has anyone got the 'Procedure for replacing the supercharger coolant pump can be found in Global Technical Reference (GTR) under section 303-03D – Supercharger Cooling. Repair Time 26.50.26 – Auxiliary coolant pump (AJV8 supercharged) – renew – 0.80hrs'.
| vnitos Member Since: 18 Nov 2010 Location: pretoria Posts: 390
also looking for this. thanks |
| All times are GMT |
