Home > Maintenance & Mods (L322) > Mix running rich / Engine Management Light
pld118
Was at the dealer's service workshop the other day having an oil leak sourced.
When they gave me the car back I started the engine and the yellow engine management light came on. They then plugged the car into their diagnostic tool, said it was showing that the 'mix was running a bit rich' with a comment that because the 4.2SC is a high performance engine that can happen sometimes. Said they'd cleared the fault via the diagnostic and it should be ok.
Anyone any incline as to what they were on about and how the engine could decide to run a bit rich having not done this before?
Thanks in anticipation Thumbs Up
Post #311408 7th Feb 2015 8:07pm
Tends to happen when the monkeys at the garage move them around, short engine cycles and a bootfull of throttle will soot up the lambda and cause it to run rich until it's been driven normally for a while...... Pete
2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior-Click here for Thread-
Post #311413 7th Feb 2015 9:09pm
pld118
Laughing thanks Pete.
Post #311417 7th Feb 2015 9:19pm
ebajema
I assume that your ECUs have all been updated with the latest software ?? My 2006 (built 2005) had some issue with the EML until we replaced the fuel pump, cleaned the entire fuel system and the inlet manifold AND updated the ECU software. After that it ran without any such issues. MY 2010 5.0 SC Galway green and sand interior!!
Post #311467 8th Feb 2015 7:02am
Maybe PMS sir Whistle Whistle Whistle Rolling with laughter
Post #311496 8th Feb 2015 11:49am
