![]() | Home > Maintenance & Mods (L322) > Best way to remove the FBH fuel pump? |
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6434
All fault codes are pointing to the fuel pump as the problem for my FBH, no ticking, so no workie.
Good idea ironhorse, thanks .
| mbmarkyb Member Since: 18 Jan 2015 Location: basingstoke Posts: 22
i have no fuel getting to my FBH either and talking to french mike he thinks ecu board but then again i do also have the fault where the fan comes on the FBH if i open a door etc so worth me getting ecu fixed.
| jon3929 Member Since: 01 Jan 2015 Location: Weston Super Mare Posts: 62
I'm trying to get to the bottom of why my FBH doesn't fire up too. FF was in for MOT and some service work earlier this week and I asked them to see what codes were generated... none.
| vaz Member Since: 15 Jun 2014 Location: Colne, Lancashire Posts: 332
There's not much space up there where it is mounted. I removed ours from underneath working between the prop shaft and exhaust pipe.
is the electrical connector one of the sealed jobs( so shouldn't be corroded?) also why did you remove the pump was it faulty? I suspect once out it you can put 12 v to it to see if its working?
Thanks for all the tips and advice. Now hopefully it will warm up a bit, I can get it out on the ramps and have a crack at it. Think I may well move it to inside the tank cover, but as mbmarkyb says, first thing is to see if it works, before heading to the pcb repair! .
| J evro Member Since: 31 Aug 2014 Location: Kent Posts: 541
Let us know how you get on Joe ( with some nice piccies please) |
If you want to try and see if the pump works before removing it.
Hi thanks for the excellent info Steve,
May be easier to get at by removing the LF wheel and inner wing? .
Vaz,
@jon3939.
Thanks,
| All times are GMT |
