Home > Maintenance & Mods (L322) > Which towbar
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
Which towbar
Hi Guys,
I'm in the market for a tow bar and wanted some advice. I don't need anything special but would like the removable swan neck affair (cos it looks better than the fixed ones)
I only have a piddly little trailer so nothing heavy duty will be towed.
Would one of these suit or can anyone recommend something more appropriate (not as a huge cost as well) Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #312007 10th Feb 2015 6:42pm
Welshdragon
Wales 2003 Range Rover Vogue 4.4 V8 Monte Carlo Blue
Shame you don't want a fixed one as pf Jones got a deal on with the fixed bars, £177 with the dedicated electrics. Mine (witter tow bar) is in the hall ready to fit when I have a day off work Cool If it dont work.......burn it!
If the IId tool cant fix it.......burn the FF.
If the FF cant be fixed......buy a Land Cruiser!
If the LC cant be fixed..............................................BUY a horse !!
Post #312016 10th Feb 2015 7:14pm
Re: Which towbar
That one will fit Thumbs Up
Common mistake Whistle
The farmers hitch is available with a pin - rather than a bolt - and so is removable more quickly than the swan neck and leaves less on the car, so looks neater.
The only down side is that it doesn't fit in the boot cubby.
Post #312030 10th Feb 2015 8:02pm
This -
instead of this -
secured with one of these -
you can even get a black plastic plug for the 50mm square armature on the car for when it's not fitted Thumbs Up
Post #312031 10th Feb 2015 8:08pm
neilw
United Kingdom 2008 Range Rover Vogue TDV8 Zermatt Silver
Just had one of these fitted. All the bits from PF Jones. Got my local indy to fit it for me - cost me a couple of hours labour, worth it though as the armature is a beast to pick up.
Used it on Sunday to bring one of my boat trailers back. Fitting it took less than 10 secs. A lot quicker than fitting the removable one in my old D3, and without the worry that it will fall out.
Now to track down the black plastic plug that I've just read about Wink
Post #312035 10th Feb 2015 8:31pm
^ http://www.fullfatrr.com/forum/topic29584.html
Dans reply Thumbs Up
Post #312037 10th Feb 2015 8:35pm
neilw
excellent, a part number. many thanks!
Post #312038 10th Feb 2015 8:40pm
comports
Neil - I don't suppose you have a link or description of the one you bought do you.
I'm happy to fit it myself (I did on the last one anyway) but looking for something with a removable ball.. Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #312042 10th Feb 2015 9:04pm
neilw
This is the one I bought http://www.pfjones.co.uk/range-rover-2005-flange-towbar.html - got the electrics from them as well.
Post #312045 10th Feb 2015 9:19pm
choplee
Going to highjack the thread slightly sorry .......I'm after the same ....,but a 2 horse box or trailer very very rarely ... just nice to know you have it i suppose .....
i see the bars under each rear strut area of the RR are westy bars to attach the cross bar on is this normal ??
Post #312277 12th Feb 2015 11:44am
Weegie
They are removed and replaced by the full armature. John
GAP iiD BT-Sold
Post #312332 12th Feb 2015 5:42pm
choplee
Ok got ya ...i see ..... going to see a friend that may have one laying about his garage for me .... not sure i'm that lucky ,but worth a shot and could be a freebie just throw him the fitting money Thumbs Up
Post #313150 16th Feb 2015 9:16pm
