![]() | Home > Maintenance & Mods (L322) > Top Tip - Sometimes let sleeping dogs lie! |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
Driving to work this morning, Air Suspension Inactive pops up (strange I never get a BONG with these..?)
I thought of you as soon as the message popped up! .
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8713 ![]() ![]() ![]() |
That's a pain Jo, do you mean the rod connected to the height sensor... Pete
OK
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1901 ![]() ![]() ![]() |
![]() ![]() ![]() ![]() ![]() If the IId tool cant fix it.......burn the FF. If the FF cant be fixed......buy a Land Cruiser! If the LC cant be fixed..............................................BUY a horse !! |
Joe
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
This is a real gripe I have with JLR main agent servicing!!! NO preventative maintenance is carried out on any service with their schedule! I check and protect the height sensors on ever service we do! It's really quite easy & straight froward! The same as white greasing all of the suspension bolts annually stops them from seizing! |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2281 ![]() ![]() ![]() |
Glad its sorted and yes sound advice I did similar with my old p38 and had to drive 100 miles on the bump stops |
I believe I will need to fit a big rubber washer between the arm and the lower suspension, to stop the arm "falling" into that gap over time.
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
i had that type of fault on an old bmw 5 series touring, it had hydraulic rear suspension, and the previous owner said it bong-ed everytime you drove it for 5 minutes. no dealer could fix it! it turned out to be a tiny version, of a height sensor...within the rear suspension mount cage, the nipple had rusted off, and it thought the suspension was flat down etc. did the same repair as you! i double nutted a bolt in place, -simples...
Morango Member Since: 19 May 2013 Location: Glasgow Posts: 21 ![]() ![]() ![]() |
Hey everyone,
Also my front left ride height is -47.47 Front right is 13.97mm
@Morango
Well….
