![]() | Home > Technical (L322) > light behind heater control knob |
They are circuit board mounted led's not designed to be changed V8 facelift Range Rover Autobiography 22" wheels.
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1902 ![]() ![]() ![]() |
Ah ok thanks Dave, looks like a new panel then |
They are surfaced mounted and if you can use a soldering iron you stand half a chance, the hardest part would be finding the led's V8 facelift Range Rover Autobiography 22" wheels.
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6830 ![]() ![]() ![]() |
I've got a similar problem and I can solder but I wouldn't even bother with this, I'd buy a replacement |
hex Member Since: 22 Jun 2014 Location: coventry Posts: 108 ![]() ![]() ![]() |
I got some surface mount LED's here from a 2010 board ( got the whole unit ! ) let me know if you want them and I will see if I can take a few off |
