Home > Technical (L322) > 2004 V8 - Cut Out - Now Wont Start
dan_uk_1984
New one to me, completely flummoxed:
Driving down the road and the engine splutters for 30 seconds and then cuts out completely, so coasted to a lay-by.
Car now refuses to restart.
RAC diagnosed as faulty Camshaft Sensor, backed up by my own diagnostics software. OBDC Code is: P0348 BMW - Camshaft Position Sensor 'A' Circuit High Input Bank 2
However, I have swapped Camshaft Sensors from our other L322 and the problem (and same error message) persists.
I don't think it's fuel pump/relay/ecu because it was running on LPG at the time it cut out. I don't think it's LPG related because it always starts on Petrol and I have turned the LPG system off now.
Any thoughts?
My fear is that the timing chain may have slipped on one bank, but I would have thought it would still splutter along on the other bank, partially firing on the bad bank. But I get nothing, other than a smell of petrol after it's been turning over and failing to start.
Post #312815 15th Feb 2015 4:44pm
wiring loom Dan? ... - .- -.
Post #312816 15th Feb 2015 4:48pm
dan_uk_1984
Thanks Stan, all looks good.
Been doing some research - wonder whether I actually have 2 problems - a questionable camshaft sensor but an actual failed Crankshaft sensor?
My understanding is that the crankshaft will definitely cause the engine not to run?
D
Post #312818 15th Feb 2015 4:54pm
http://www.fullfatrr.com/forum/topic23644....aft+sensor
http://www.fullfatrr.com/forum/topic5503.h...aft+sensor
you've probably read these already but it might help.. ... - .- -.
Post #312820 15th Feb 2015 4:59pm
johnboyairey
I bought a new crankshaft sensor, around £45 I think, it's under the sump area. - didn't need it as mine was a camshaft sensor after all. - they are more expensive, but you have two to prove yours. However, I would be worth retro-proving your own bits onto the working l322 you have to prove the fault...
Post #312821 15th Feb 2015 5:04pm
dan_uk_1984
Unfortunately Stan, both of those posts have no resolution, I assume after Vento got the car fixed he left the forum Smile
Good shout John - I'll try and grab the Crank sensor out of the other one to swap over...
Post #312843 15th Feb 2015 6:06pm
dan_uk_1984
Got it booked in to a garage to get the crankshaft sensor replaced, will tow it with the other L322 following the towing procedure.
Post #312998 16th Feb 2015 10:34am
johnboyairey
the crankshaft sensor is a two minute job, two allen head bolts, and a connector. Then pull it out...i did mine at off road height, spare wheel under the sidestep, lay under step, and reached under. mine was stranded, so it was easiest option. as said, i needed a camshaft sensor, (another 2 minute job,) i couldn't find a secondhander, and new was an order in job, so i found that an ebay seller did them new for a m62 engine, but they had a male socket on, not the famale i needed, so as it was only £15 each, i solderered them to the old females, and ---VROOOM!
http://www.ebay.co.uk/itm/CAMSHAFT-POSITIO...2ed32182eb
Post #313051 16th Feb 2015 3:01pm
dan_uk_1984
Unfortunately it turns out I have no compression on one bank - this means the valves are not operating as they should.
So at this point I suspect a serious issue with the timing has occurred. Either the chain has jumped or something worse. It's common for the plastic chain guides to fail as they wear over time.
Garage is going to lift the camshaft cover tomorrow to see what lies beneath.
Will keep you posted.
D
Post #313570 19th Feb 2015 12:33am
dan_uk_1984
To follow up - the plastic timing chain guides (yes, plastic, Thanks BMW!) had failed and become snagged in the chain and ripped off, the chain was then allowed to move, which pretty much destroyed everything.
£3,500 later, I've just had a reconditioned engine installed... can't say I love her anymore so about to put her on eBay Sad
D
Post #321330 5th Apr 2015 8:26pm
verydisco
Sad to read this Confused but thank you for the update Thumbs Up l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #321332 5th Apr 2015 8:28pm
Prepros123
England 2004 Range Rover Vogue 4.4 V8 Buckingham Blue
Had this happen to my last one. Timing chain jumped because of worn plastic guides. Is it feasible to have these changed as a preventative measure though I should imagine it's a PITA of a job
Post #321391 6th Apr 2015 8:48am
Starberg
Sweden 2003 Range Rover Vogue 4.4 V8 Java Black
Sorry to hear that mate!
At what milage did this occur? L322 Vogue 2003
Post #321398 6th Apr 2015 9:36am
Prepros123
Mine happened at 160000 odd so no idea what expectation is
Post #321408 6th Apr 2015 10:14am
